Carbon Fiber Tacoma Bed Replacement Camper - Build Thread
Victorian
Now that I had the basic rough shape and dimensions of the camper mocked up it was time to start shaping the foam. This method worked quite well to be able to see how the lines and contours lined up and followed those of the truck’s - much easier to visualize in real life rather than in my CAD model.
I wanted a nice big, round radius around the back corners of the camper to mimic the swooping corners you see on the back side of the cab of the truck. One thing I realized about a lot of the campers that I have admired is that they're built on relatively "boxy" shaped vehicles which isn't really the case for the Tacoma. So the extra shaping really seemed worthwhile for the overall aesthetic of the build.
After much deliberation on the pros and cons of all the chamfers and radii I was adding I decided to finalize it by moving on to the next step - fiberglass. Since I would be using this full size plug as a master mold to create my production molds from I knew I would need the various surfaces to be perfectly flat and smooth. To get a stronger foundation for all the body work I was about to do I added a layer of fiberglass boat cloth and epoxy resin. This would give me a hard shell to add Bondo to before sanding everything to perfection.
Here you can see a layer of boat cloth on the side of the plug before getting wet out with resin.
Here it is after wetting out the fiberglass with resin. Not a very fun job and it leaves lots of little ripples to take care of in the body work later, but it's necessary to give solid structure to the plug. You can also see in this photo some of the green fairing compound I had started to use for flattening the main panel areas. Some of this ended up being a waste of time for reasons that I'll describe later.​
Epic!
I did this in a smaller scale for a 15 gallon Motorcycle tank . Good luck!
Leighsjor
After finishing adding the layer of fiberglass to the entire plug I turned my attention to fairing out the large, flat surfaces first. This is when I realized I had gotten myself into more than I bargained for, but such is life - gotta push through the pain and get the job done. I am, however, embarrassed to admit how many hours and layers of compound I spent flattening these surfaces. I'm sure there are plenty of people out there in the composites community that would tell me there's easier ways to do this, but hey - you live and learn, right?
Here you can see exactly how wavy the layer of fiberglass and resin had made the surface. I used a long board sanding block that I made out of an approximately 40 inch long honeycomb cored frp panel. This made for a really fantastic sanding block as it's perfectly straight and really revealed all the ripples through the first layer of fairing compound, but man alive did it give the shoulders a beating!
After many hours of sanding I just had to put it back on the truck to see how things were looking. It's always good to do whatever you can to keep your final goal and motivation intact!
Leighsjor
Continuing with the theme of body work, here's some more progress photos. By this point in the process I had glassed in an upper flange that would be used to attach tent canvas to the lower body portion of the camper. It's well oversized for what I actually needed because this flange would also need margin to attach my vacuum bagging to the mold once it was made.
And here's the driver's side of the plug after a fresh coat of primer. You can obviously tell there's still quite a few imperfections, but it was getting closer! Right around this point in the process I finalized my decision on the plan to only use the sides of this plug for making molds. Previously I wasn't sure how much of the front and back surfaces I would use for making molds. I could have even made a multipart bolt together mold so the camper could be laid up in one rigid piece (monocoque) but I realized that the best way to allow for some flexibility in the structure of the camper as a whole would be to bond midsection panels together to the two side shells in order to have flex joints. As many of you know Tacomas are notorious for their flexible frames. If the camper were one rigid structure bolted directly to the frame I would be concerned about stress fractures in the composites over time. We will talk about this more later as I show how the camper gets mounted to the frame of the truck.
Leighsjor
Finally, after hundreds upon hundreds of hours of sanding I was close to the finish line on the body work of the plugs. It was time to do a big scary thing. As mentioned, I planned to use only the sides of the plug for making molds so I decided to reclaim some of the space in my shop by cutting the sides completely off and discarding the midsection. Here's a short time-lapse of that process.
https://youtube.com/shorts/alAo7o6T1Pc?si=IWNZ8ysHBniSkQiJ
(Sorry for the link only, apparently you can't embed YouTube shorts)​
And here is the aftermath:
As you can see they're getting very close to being able to make some molds from!
Here's another video that I shot after one of my final coats of primer:
Leighsjor
As an intermission from the process of finishing body work I turned my attention to learning the process of vacuum infusion. I received my first batch of sample materials and decided on a few different layup combinations that I wanted to try to test strength, weight, and to acquaint myself with the process in general.
Arrival of our first sample materials as well as some equipment.
It was around this time that I realized that I absolutely love the process of vacuum infusion for composite materials. It's so fun to see the part get infused with resin knowing that it will be a fully functional part after cure and de-molding all without the mess of having to spread resin or wet out materials manually. Here is a timelapse video of my first attempt at infusing a small 12x12" sample panel:
And here is the result after de-molding and trimming the panel.
Again, I did a number of these sample panels in order to test multiple different parameters before deciding on the ideal layup combination that would be used on the camper itself.
Leighsjor
After finishing multiple test pieces as well as well as experimenting with some fiberglass mold making I decided it was time to dive back in and finish the last bit of body work on the plugs and prep the them for making molds. Here's a walk-around video of the driver side plug with body work 99% complete and ready to add flanges for making molds.
And here's a photo after adding flanges. I enlisted the help of the wife to add the wax fillets to the flanges. She's a dental hygienist, so this kind of detail work was right up her alley. ;)
Here's a video of the plug fully in place and 100% ready for gelcoat and fiberglass for mold making.
Next up - let's make some molds!
V45W_Proto2.5
