2020 Overland Explorer Vehicles (OEV) CAMP-X pop-up slide-in pickup camper (renamed "Back Country" as of 2023)
wackyhacky76CO
When I purchased my 2021 Camp-X, the front fan cover was broken. After inspection, the only way to fix it was to replace the full fan assembly. I did this myself with not much hassle. I will note, the roof will dent from your knees. I recommend using a board or pad to distribute your weight. I am not a large guy, and I have some small deflections where I was kneeling. When replacing the front fan, I inspected the rear fan, and it was very similar looking to yours. Since I had the dicor out and open, I covered all cracks with it and have had no issues. I did not use the self-leveling Dicor.
Cool! I appreciate that input. I wasn't sure if I should use Dicor or Sika flex when replacing them, which I have decided to do. I would rather have the pc of mind to know they won't spring another leak down the road when we have forgotten about it and might replace them with style that allows fan use when raining.
Chadx
♫ Offroad, again. Just can't wait to get...♫
The Maxxair Deluxe fans are great. Not sure if they are direct replacement (opening, wire size, etc.) but really love how they work in the real world vs the standard. The electric opening/closing is a nice feature, though the gears are a bit noisy. You can manually crank the vent open and closed if you only want it open a crack (the electric opener opens it all the way). Having a remote control is a nice touch. And there is a handy built-in light in the fan shroud. Keep in mind the Deluxe is taller when both closed and open if clearance is a concern.
Ninelitetrip
If I recall you purchased a used 2021? So no warranty likely, but I will still reach out to Arnold on best replacement method. I had a full replacement done at a dealer a few months after new for the motor. They do the job but not the sturdiest of appliances.
wackyhacky76CO
Good Call... and I actually did that yesterday to see if they would provide any insight or technical direction. Just waiting to hear back. My local dealer said I could even go Camping World if I was in a rush to get them replaced, and that was when I was like, "ya know. I can just do it myself." The Deluxe model should work nicely They are slightly taller (and longer) closed, but not by much and all the other installation specs are the same, still a std 14x14 opening & 12V 5amp power and roof thickness required is actually less than the Maxxfan Plus.
wackyhacky76CO
For anyone that may ever need or want to tackle a fan replacement, direction right from the man himself.
Hello Keith,
Unfortunately, the plastic UV additive seems to be hit and miss with any of the roof fan products. This is incredibly frustrating, and we wish they would all improve their QC regarding UV protection or develop an all-aluminum housing. To add to it, they do not even provide torque specs, we have requested it and got nothing back from them other than “do not over tighten the fasteners”.
The OEV powder coated aluminum mounting flange should be issue free, outside of a reseal around them periodically upon inspection. Use a Sika 221 to re-seal the perimeter of the mount flange to the roof. Ensure the area is clean and dry prior to sealing.
The fan itself requires a product called Silaprene Solidseal. After removing the old fan, ensure the entire area is clean and dry before applying any adhesive.
Process:
- apply 2 beads of "Silaprene Solid Seal" around the wider edge of the shroud covering all the holes
- apply 1 bead around the narrow edge of the shroud covering all the holes
- Place Maxxfan on fan plate, make sure the hinge on the Maxxfan is facing towards the front of the roof
- attach using 10-24 x 5/8" Buttonhead screws (Do Not Over Tighten)
- Scrap and clean off any squish out with ISO 99%
- seal all button head screw tops
I hope this helps. Alternatively, you can take it to the closest OEV dealer or any RV dealer service center to have this done.
Regards,
Arnold Baker
sumnrfam
Retired or just tired….
@wackyhacky76CO ,, like @Chadx mentioned,, it depends on the torque,,
I use a Milwaukee 12v and it took me a couple of tries before I realized it only worked on the higher torque (lower speed) setting,, the other setting did what you are experiencing and gave up once the heavy lifting starts.
Also,, I do the same 2-3” bites off of each corner to keep the camper as level as possible during the process,,
wackyhacky76CO
Hello Keith,
Process:
Regards,
Arnold Baker
Just a PSA for anyone that wants or needs to replace the fans in their camper. Overall, it went pretty smoothly, but I was not able to use the Maxxair Deluxe fans as I had originally hoped. It could certainly be done, but the OEV installation design does make moving to another fan somewhat difficult without some fabrication work that I frankly decided against in the end. The mounting flange on the deluxe fans is a completely different size (in terms of mating to the OEV aluminum mounting surface) meaning the hole pattern (which is drilled & tapped) would need to be completely altered to use a Deluxe fan. Therefore, I just ended up buying the same MaxxPlus fans b/c I didn't want to get into the fab work required to do it. After 3-4" of snow fell & melted over the past wkd, I think I can safely say I no longer have any leaks, which is an incredible relief.
wackyhacky76CO
Hey everyone! Looking for some input on the Truma AquaGo. So I followed all the instructions to dewinterize the Camp-X to the letter. Once all lines in & out were flushed, I opened the bypass & tested the water heater, which worked immediately. Happy I turned everything off as noted. Two days later we were camping and couldn't get it to fire. I tried several resets and what I could remember from the manual and it turn on but not heat. It was giving me an E-1-W error message and not heating. At a couple points the AquaGo icon on the display even disappeared and then came back, but on after I reset it. We didn't have the manual with us, so we gave up. Tonight I went out and went through the start up instructions again and she started working as soon I clicked on the power switch (outside). I went to check the display & once again the icon disappeared, but it was operating and heating. Then I switched it back off, reset the control/display and the icon returned. Then I tested it again (in sequence), power on & then using the control panel/display to activate Comfort mode & it worked fine. All that being said, the unit is incredibly noise when the hot water is running. First, I thought it was cavitation in the lines, but it is definitely a loud noise from the unit itself. Is this "boiling noises" they reference in the manual signifying it's time to decalcify the unit? I am hoping that is it but wanted to get some input. Below are links to the noise inside & out...
MisterSmith
I don't have any of the issues you mentioned, but mine has sounded like that since day one and has worked fine for the last 3 years.
MisterSmith
I made another batch of Mollenuts....
Mollenuts are a convenient way to mount things to your OEV Molle Panels. They're specifically made for the panels on most OEV campers.
There are 3 different form factors for the Mollenuts:
A.) Vertical orientation — $14.00 each
B.) Horizontal orientation — $14.00 each
C.) Full Square — $15.00 each
Why are they so expensive?
  • They're made from 303 Stainless Steel with Black Oxide coating to resist corrosion
  • I can only afford to make about 100 pieces per production run
  • I'm not a company, just a dude who needed these for my OEV Molle Panels
  • Because somebody put tariffs on stuff
  • I can't find someone in the USA who will make them cheaper or take my order
How do I use them?
Here's a picture showing the back of my left side Molle Panel. I used them to mount my Axe/Shovel mount and Propane Tank mount. Notice that I used all three types to get things to fit:
In this picture, I'm using 4 pieces of type "C" to mount the Pelican case that holds my Starlink:
L Bracket mounted on the front:
Tie down ring mounted on the front:
Technical Details
These are the drawings showing the dimensions of each type of Mollenut:
Vertical:
Horizontal:
Full Square:
Ordering
I'm not a storefront — just a guy doing small-batch production runs and shipping them out in a USPS flat rate box.
Flat shipping fee: $10.50 per order (up to 100 units)
Order or learn more:
https://www.contactdi.com/mollenuts
If you have questions, there's a contact form at the bottom of the page.
PaulPritchard
ArizonaPaul
MisterSmith - I just bought a truck similar to the one in your photo. Curious what you used to raise the camper to sufficiently clear the top of the cab. I am using a stall mat but that might not be enough.
Those molle nuts are great BTW. I used them to install my Little Giant ladder carrier and recovery boards onto my molle panels.
PaulPritchard
ArizonaPaul
I have a Redarc question. My Camp-X camper is off my truck, in my garage and plugged in to shore power. For whatever reason I cannot get my lithium battery to charge greater than 97% whereas before I've always charged it to 100%. The battery is four years old.
OEV suggested I reset the Redarc and referred me to the manual. I couldn't find any reference on how to reset it in the manual.
Is there an easy way to reset the Redarc short of having to disconnect anything? Thanks.
MisterSmith
Hi Paul, I'm not using anything other than the stock "rubber pucks" that came on my CAMP-X. The height is fine on my 2021 F-150
Ancientsojourners
