FUSO, ** SOLD** Expedition Vehicle
GR8ADV
Simplicity to perfection
Arguably the most robust, reliable, capable and comfortable FUSO build. At this price point I can pretty much guarantee it. You can go most anywhere tomorrow, and be assured of a beast of a rig.
It needs NOTHING, zero, nada. It is ready, robust and redundant and needs only fuel to drive it to Panama (or your nearest national forest) tomorrow. No investment of any kind required for full on expedition travel after purchase
Without a long and drawn out advertisement (edit, well so much for that idea) I will highlight what I believe are the real world important items on this vehicle as it relates to overlanding/travel. There are more specifics and details of this build. I will be happy to share with anyone. Again, it is 100% sorted out with real time use, and is as exceedingly reliable and capable as it is comfortable.
It’s registered in Washington as an RV and insured by State Farm as such.
Highlights here with some pics. The next two posts will go into a bit of the cool history of the rig, some more details and other stuff as needed.
TRUCK
What makes in unstoppable…
-2004 Fuso FG. Before DEF, uses any diesel,
-its simple. Crazy robust. Easily serviceable in most any city. We have a couple great service centers here in Seattle, they do all the work on it. It is serviced regularly.
-185,000 miles and growing. So about ½ way through its life. It runs to day exactly like it did a dozen years ago. I would expect it to be running long after you are done with your adventures.
-Automatic with Low speed transfer case. NO Duonic/Moronic transmission. It will crawl through most anything you could imagine.
-Super Single wheels from FUSO off road with E rated tires for about 4000 LBS each.
-Parabolic suspension and shocks from ATW. Super comfy
-Quaif limited slip up front to match the LTD slip in the rear.
-120 psi air compressor with tank for air ups lasting about 1 min per wheel
-60 gallons of fuel for 600 mile range.
-More external storage than one should reasonably use
-Baja suspension seats
-20 feet in total length, 11ft 6” high
THE HOUSE
-This is where you live, not where you exist. A place to really enjoy being in, not just a white box of ‘excuse me’ you are in the way. This is NOT a van. It is spacious inside. Internal quick video.
https://youtube.com/shorts/upL2Br7mLzw?si=ByeH_6aaz6IyPEsO
My design philosophy was simple.
-it needed to be a comfortable enjoyable place to live.
-It needed a full size comfortable couch
-Queen bed, as comfortable as one as at home. No foam pull out crappy nights.
-When the Bed was in use the other person has full access to everything in the rig.
-lighting and book shelf at the head of the bed.
-a dining set up such that two people could sit across from each other.
-it needed a horizontal surface other than the kitchen counter to put stuff, keys, books, maps etc, that didn’t get in the way of cooking.
- A big fridge and freezer so I didn’t spend my vacation shopping every couple days.
-it needed a shower with a cassette toilet. With unlimited on demand hot water.
Then I let the Master Carpenter Paul Jenson take over. The results are in the pictures.
Price. $110,000. Or any offers. Now that I have decided to part with a decade+ old fried, I kind of want this to happen quickly. The rig owes us nothing. What a run. Enjoy the pics and thanks for looking.
Ken
GR8ADV
Hold open for updates
Propane two burner cooktop. Clean cooking and way better than diesel. I prefer to cook on gas than induction as it is and it requires no energy. We also like the propane for the outdoor bbq so it is a natural choice . We fill the tank after 2 months or so.
-Propane fired Water heater. On demand unlimited supply of hot water.
-Insta hot (we only need the propane fired heater for showers) the insta heats up in seconds for dishes. Two minutes for tea.
-Compressor fridge. 12v or 120. 8-9 cu feet
-30A shore power
-Morningstar TS45-MPPT charge controller
-Bogart Trimetric 2025-RV battery monitor
-Magnum 2000w MS2012 sine inverter. Runs our insta hot, runs our espresso machine and milk frother. (Damn Seattle people). You can go bigger. Never ever needed any more.
-Webasto diesel heat.
-Fiamma eagle electric awning. So nice. We feel spoiled whenever we push the button.
- 2-200 w and 2-100+ w panels. 600 + W. Could upgrade easy to 800w by replacing the 100’s. Could likely go way up by replacing all 4 with new different sized ones if you wanted. That said, we almost never go below 80% on our 400 ah lithiums.
2 new agm for the cab,
2 new 400 amp hr lithium for the house.
60 gal of fresh
25 gal of grey split between shower and sink.
600w of solar
Complete new AC for the cab
New brakes
New drums
While doing the front brake system I had them completely rebuild the locking hubs.
Nothing regarding mechanical robustness and reliability is ever ignored on this end. We simply can’t afford that while exploring.
Everything you see in the pic came out of the external storage from our Baja trip we just came back from. No boxes, spare or anything for that matter bolts onto or hangs off the back. Everything tucks away with room to spare.
FWIW the bbq is almost embarrassingly big. lol. It connects to the propane tank externally. It can go on either side or in front of the vehicle. So we can always cook away from the sun, rain or wind. Just one of the many ‘little things’ that make the difference.
Based on questions. Here are some more pics.
Pass through open and closed. It opens from the inside with one hand. Need the secret to open it from the cab. Unless your name is Liam Neeson I can’t tell you unless you buy.
Not sure why, some loaded some have attachments to click on.
Some storage. Yup everything from above. The air compressor is fixed in a storage hold and that where we put air lines and the air assist hydraulic jack.
Propane tank lives in a storage unit with the stairs and all fluids.
Truck batters are locked
Rear is huge and the spare lives there. Air tank below
Side storage runs all the way across the rig and opens on both side. Nothing you own is 8 feet long. Lol.
House batteries and mppt solar controller, solar kill switch, inverter and house kill switch’s all together.
We were one of the only two vehicles capable of gettting across the river to TUK. They wouldn’t let anyone else on that wasn’t capable of getting off. Wife’s commentary is so funny. https://youtube.com/shorts/wytYgMKeO9k?si=emhHhOqdUHxli8L0i
GR8ADV
Hold open for updates.
The rig is somewhat famous in overlanding lore. Kim and Don Greene originally had the rig built. (Although we have completely remodeled it and done heavy off-roading mods to the truck itself.)
They wrote a book about it and their travels with it through the Americas. Book included in the sale.
GR8ADV
In response to some questions.
How the bed works. Simple. And doesn’t waste all that space all day long. We keep the sheets and pillows within so when lowered it is made. One could sleep in it while up if need be.
https://youtube.com/shorts/t1SgBApm6_c?si=1tQius2M7IILgym7
How the table works.
as we enjoy the couch 90% of the time, we wanted a very nice one and didn’t want a rig focused on a dining table used much less. Easy peasy
https://youtube.com/shorts/JgAhiPyTAsM?si=A72UYpHZt0UALYdS
CONTROL CENTER
mhiscox
Exp. Leader Emeritus
Well, dang, Ken. Not surprised, but it's always sad to see one of the "overlanding before it was cool" group sell their long-term rig. Good luck with the sale.
And to the other 232K members . . . You should know that this is a very nice rig with great capability and if you are ready to move to a usable expedition truck, this certainly deserves your attention. Indeed, it is pretty much ideal for any couple or solo traveler who sees merit in the built-not-bought ethic and is ready to take advantage of its ability to leave tomorrow for just about anywhere.
Lots of the cool kids covet a bigger or more expensive truck for the status, but the amount of liveability offered in Ken's compact and easy-to-drive Fuso is just about unbeatable given its off-road chops. And the asking price seems very fair; I don't know what else you could buy for the same money that will get you as far off-pavement while giving you such a comfy place to live when you get there.
I've no vested interest in the sale but, back in the day, the work Paul Jensen was doing under Ken's direction to remodel the Greenes' habitat was one of the ExPo build threads we all followed. Their work turned out unique, capable and functional, and it seems to me--and, I suspect, most other 20-year veterans--that the strengths this setup has should still count in this day of quarter-million dollar Sprinters and half-million dollar F550 conversions.
Roam.Wild
Looks great! The interior quality is refreshing!
What is the battery type and capacity? Fresh / grey water tanks? Solar?
GR8ADV
Some storage. Yup everything from above. The air compressor is bided and that where we put air lines and the air assist hydraulic jack.
Lotso detailed storage pics added above for those asking. Enjoy!
GR8ADV
All this stuff I forgot to put in the first write up. Now added. Thanks for asking.
60 gal of fresh
600w of solar
New brakes
New drums
Thanks again for the reminder.
GR8ADV
Manual or automatic transmission?
Auto with low speed transfer case. Damn I do suck at this.
This set up is the perfect, and for that matter ONLY descent set up for the Fuso off-road. It is staggering how well it pulls in low range.
The Duonic transmission they ‘evolved’ to made the Fuso pretty useless for anything but service roads.
Thanks for the question. I will update my lame ad.
GR8ADV
I am generally surprised at the one question I get from everyone. “What does it need”. Do people sell vehicles that needs work all the time??
It needs NOTHING, zero, nada. It is ready, robust and redundant and needs only fuel to drive it to Panama (or your nearest campground) tomorrow.
No investment of any kind required for full on expedition travel after purchase.
davidtzlu
Thanks for your quick responses. A couple more.
I’m not familiar with these earlier fuso fgs so forgive my ignorance.
So some basic questions:
Wheel base?
Track width?
What is a typical comfortable highway cruising speed on US highways? I know everyone says slow down but this is important to me and the wife …..
GR8ADV
Wheel base?
Track width?
Wheel base is 133. Track is around 65.5 I believe with the super singles. Very maneuverable, and tracks in regular vehicle ruts.
The joy of the cab over is that it t is roughly the same overall length of the small 144 wb sprinter yet the living area is palatial. It’s taller and wider but parks in a regular spot at the grocery store too.
With the 37” tires it cruises all day long comfortably at a real gps read 65 mph at 3000 rpm on the interstate. Tops out around 73/74 based on our return up the I-5 last week. Considerably slower on hills.
xander69
