2022 Ford F550 - DIY - Adventure Expedition Vehicle Build Thread
Vance Vanz
LINEX - Exterior of Cab & Details on the Cab
I thought I would post a few pics of the back of the cab, while the camper was off the rig, as well as some additional photos of the finished details on the cab. These pics also have better lighting, which shows the black and light grey colors of the LINE-X a little better than previous photos.
As far as the seams on the doors, on the black lower rocker panels, we played with wrapping the edges just enough so your eye wouldn't see/catch grey when walking past them. We also didn't want to wrap the black too far around the edges of the doors, or into the door jambs. It came out well and looks balanced. These are all the details CeeCee was willing to take the time to address and dial in :love:(y)! It's not easy getting super clean cut lines on LINE-X.
Vance Vanz
Auxiliary Fuel Tank & Factory Carbon Canister
So, I'm finally getting to some of the modifications/additions to the factory truck/truck chassis. "Why now, this late in the game?" you might ask.
Well, when I purchased the truck brandy new back in 2021, no one had a 50-55 gallon aftermarket fuel tank for a F550 in diesel or gas. The price for a custom tank was outrageous and no one I contacted at the time wanted to build one either. So, I waited.
When one finally came out, I was already up to my neck, or should I say drowning, in carbon fiber composite and body work. As soon as the truck/camper headed to the LINE-X shop, I started sourcing everything that needed to be mounted to the truck/truck's chassis. The first order of business was the additional gas tank. Everything needed to revolve around this.
So here we go............🥳
Factory chassis layout
Moving in
Semi done
Now what do I do with this?
Of course the bottom of the emissions carbon canister is not flat. Why would they make it easy to ditch the factory bracket and just remount the canister to something flat? And of course the bolting pattern/orientation for both sides of the canister is not similar.
😕😕😕😕😕😕🤔🤔🤔🤔🤔🤔🤔🤔🤔.............. I went roundy round on where to mount this thing and how to mount it. I wanted to keep it as high as possible, above the water line, and keep the whole process as simple as possible. Believe it or not, I'm starting to get tired of fabricating things from scratch on this build.
🧐, let's just reuse as much of the factory bracket as possible. A little snipping and then some adding.
Now I can can mount it to something flat 🤓.
To be continued................., time for bed 😴.
Vance Vanz
This jankie website. It stopped sending me update to this thread. Amazing progress, my dude.
Thanks 38snubby 😁. I appreciate it.
We're all in the club of NOT receiving updates on the threads we subscribe to. A lot of the time, I don't even receive updates for my own build thread :LOL:!
Just check in about every two weeks; it's about the max frequency I can post with the amount of hours I'm putting in on this beast (y).
Vance Vanz
Auxiliary Fuel Tank & Factory Carbon Canister - Continued......
Someone inspired me to post a little sooner than I normally would.
Finally landed on a good spot for the canister 🤓🥳!!
A little welding here
Some fabrication there
And a whole lotta dry fitting everywhere
Well....., let's not forget about the onboard air! We might as well get that sorted while we're playing and making: brackets, brackets and more 😋😛🙃😝😜🤪 brackets.............🤯!
Vance Vanz
ARB Onboard Air System
Let's get it all out and sorted.
Another part/aftermarket system that I have to ditch all of the factory provided electrical wiring and connectors, because they are sized too small. Don't you love paying lot's of money for components on expensive systems that you can't use and/or have to throw away ☹️😣😖😫?
Back to those da(😡)mn brackets.
I drilled some additional holes for mounting routing electrical wires and airlines as well. Don't want that to be an afterthought :oops:🤬!​
With limited space under one of the last available factory-chassis-cross members at the back of the truck (highest cross members on the truck-to stay above the water line), real-estate was tight. I wanted to get the canister and the ARB compressor mounted at/on this single cross member (behind the cab). All other available locations to mount both of these items, put these two items at least 8-10"s lower in height.
The placement of the canister/compressor (at/by the gully in the top of the tank) allows for a perfect path for the vent lines on the canister, and the electrical wires/air lines on the compressor, to be routed over/through the gas tank and to/along the chassis rail. Also, the air inlets for the ARB compressor (that you can see in the above pic) will also get 90's and short nipples to increase the height of the inlets. This will put them just above the top of the chassis frame (37.5-38"). My water line is 34", a 1/2" or so below the bottom of the doors, so I'm trying to keep everything at 37-38" minimum off the ground. These are all of the layout and fitment details that take so much time to consider and figure out, but make the install so much smoother 😎!​
There is plenty of clearance from the exhaust and driveline and the canister/compressor are also easily accessible for service if needed. Although the compressor could be installed in a more water tight location (like under the hood. I tried, no room), the whole front side of it is protected by the bracket for the canister. It's also tucked up tight enough (under the camper and between the chassis rails) that it should, hopefully, be fine from the elements.​
Vance Vanz
Heating & Free Heat System - Rixen
Let's just keep rolling on BRACKETS!!!!
For all of these systems that I'm currently going through, it's not just the mounting/brackets that I'm figuring out. I'm going through the entire system, any and all elements of the system that I have not already sorted/finalized. This includes where and how it will be mounted, fabrication, material/hardware, electrical (sizing/wire/fusing/terminals/loom), fuel/vent/air/water/etc.-lines, fittings, sealers..............., etc. You get the idea! I'm finalizing and sourcing EVERYTHING, so I am basically 100% ready for the install (when it comes time for the install).
This is what I have been doing while the rig/camper have been at the LINE-X shop and the interior paint shop. As soon as I come up for air, after getting one system complete, I dive right into the next one. It's a bit BONKERS 🤪 how long the design and layout, alone, can take, not to mention the time finding, pricing and sourcing all of the parts. After all of this, there are also several (hopefully not many) rounds of dry fitting and re-adjusting (if needed).
And the reward for all of this hard work and seeing everything dry fit (2-3times)...........?, take it all apart, put it back in the boxes and wait for the final install 🙃😣😫............... 😆. Prototype builds are MADNESS............., especially when you are basically doing it alone 🤣. Oooh Man; I'm pissing myself right now 😂, about how much time all of this takes and how absurd it can feel at times!!!!
"Just keep moving forward" 🤕🫡.
Rixen System (Outside of camper components):
Pulling everything out
This is where the outside components will be mounted
Espar, plate exchanger & fuel pump
A little DIY CAD
Snap your fingers three times............... and it magically appears!
Did I mention about the process of dry fitting yet :)? (#1)
(#2 &3)
(#4)
Vance Vanz
Heating & Free Heat System - Rixen - Continued......
Getting the electrical, air intake and exhaust routed and dialed in, as well as drilling all of the holes in the chassis for mounting any/all lines (#6)
It's hard to see in the pic, because of the lighting, but I was stoked to be able to tuck the end of the air intake behind the bracket, which basically creates a little protective tube around the intake. This will help cut down on the dust/dirt/debris/elements reaching the inlet.
It was late, so I called it a night, but I had a little whisper that I couldn't put my finger on. The next morning I woke up and said "That fuel pump is not in the best spot! Although......, it is: in a good spot for serviceability, tucked up high enough, technically protected and the chances of something catching it are veeery slim! BUUUUUUUUUUT, there is still a chance that a branch and/or stout bush could catch the pump/fuel line, given the right 4x4 angle on the truck when the stars and moon align once every millennium!"
Sooooooo, it was decided (begrudgingly 😤), to move the da(😠)mn fuel pump 😁.
Roundy-round 🤔, Roundy-round 🤔, Roundy-round 🤔 and 💡🤓! "Mount it right next to all of the other fuel pumps, where you will be able to still access/service it when the camper is on." "Yes it will fit; just try harder and make it fit! Don't be lazy; this is not that kind of build!"
Factory fuel pump, Aux. fuel tank pump and Espar Rixen fuel pump. My little fuel pump farm.
Still serviceable from the ground/bottom side when the camper is on.
I can also route the fuel line with the existing factory fuel lines (Bonus).
It may take me awhile, but I'll get there eventually!
I also laid out and drilled several mounting holes down the chassis rail for mounting fuel fill/vent lines, as well as the coolant lines for the Rixen system (before the camper gets permanently set). I'm still not sure If I will be running the lines on the chassis rail, or the bottom of the camper. There are pros and cons for both, so I need to chew on it a little more. The holes also got some primer and paint (not shown).
One last piece of info that may be helpful to someone before we move away from the Rixen system (any system using the vehicles coolant/radiator for free heating). I was chatting with the neighboring build shop, when they were doing work on the ER (and it's heating/free-heat system). We started chatting about Pros and Cons of where to place the free-heat plate exchanger (Plate exchanger connected to the vehicles radiator/coolant loop).
One school of thought is to keep the vehicle to free-heat plate exchanger loop as short as possible. Meaning, mounting the free-heat plate exchanger as close to the vehicle's factory loop as possible (Basically, under the hood/at the engine). This minimizes the effect on the factory loop as much as possible and reduces the length of the coolant lines and number of fittings that could be susceptible to leaks. These are all Pros for a shorter factory vehicle loop (vehicle to free-heat plate exchanger).
A Con of this set-up is when you are not using free heating (coolant from the vehicle), and are using the Rixen Espar heater (in my build case) for heating (using fuel from your vehicle’s gas tank to supply/feed the Rixen Espar heater). With the free-heat plate exchanger being at the front of the vehicle (smaller free-heat loop), the heating loop is now longer. You now have to heat a longer loop when using fuel from your vehicle. Maybe not a big deal during the summer months, but if stationary during the dead of winter, you are now heating longer exposed lines (to the front of the vehicle).
The second school of thought is to put the free-heat plate exchanger at the back of the vehicle, or as close to the heater as possible (Rixen Espar heater for my build). The Pro of this setup is the heating loop is as short as possible and you heat a shorter loop when stationary (save on fuel). The Con is you have longer coolant lines and possibly more fittings in your vehicles factory loop, which could result in a leak and affect the vehicles factory coolant system (No coolant in your vehicle means no Drivey, Drivey and No Overlandy, Overlandy 😊)
I know this is all a bit wordy and unfortunately, NO, a diagram will not be included. Unless, someone else is feeling spunky 😁!
Yes, we could add more plate exchangers and pumps to the mix and start talking about multiple options and scenarios, but I'm keeping this related to just the use of free-heat from the vehicle.
I appreciated the conversation with my neighbors and it got me thinking about the question we often ask, "What is the BEST method?" Of course, the answer is often/always "It depends!" It also got me thinking about how we may do things without fully knowing why we are doing it the way we are doing it. After explaining what I was doing on my build, I had the ability/courage to ask them if they would do it differently, if they were building my build. Their answer was yes and I appreciated it.
My neighbors like the shorter free-heat loop to minimize the chances that the vehicle's factory loop could experience an issue. They were also mostly basing this off of seeing many shi(@&@&)tty installs. I agree with their points, but I prefer a longer free heat loop and a shorter heating loop.
Personally, If I'm going to tap into the factory system for free heating, I'm going to maximize the amount of free heating I can get. I'm also meticulous when it comes to building something, so I'm not worried about a sloppy install (The type of install where an unprotected/improperly routed coolant line would be rubbing on the factory chassis, or some other object it should not be rubbing on). In addition, mounting my plate exchanger at the back of the vehicle resulted in the same number of fittings I would have had to use if I mounted it close-ish to the engine.
This is all just food for thought and I wanted to take the time to mention it, since it happened during my dry-fitting-fun of the Rixen system. There is also one other addition I made/will install in my free-heat loop based upon previous experience of running this system in other builds, but no time to cover it now.
Enough Build-Threading for today. It is time for some Din Din and then back to designing the rear bumper/winch mount/spare tire carrier Combo and the rear roof ladder 😳😫🤯!
Vance Vanz
Getting Back in the Saddle
Time Flies!
I guess I should get some content posted.
I’m going to start jumping all over the place, because that’s how the build has been going 🤠.
Rear View Mirror Split Camera:
Testing everything out.
I wanted to run a camera on the front of the truck (grille/bumper area-centered), as well as a rear camera on the back of the camper (as high as possible-centered). The system will have small clean modern matching waterproof cameras. These two cameras will be run off of the aftermarket rearview mirror camera. You can toggle between one screen (front or back camera only), or a split screen for both cameras. It will be nice to see behind the camper (from a high vantage point) for normal/highway driving and also the front lower portion of the truck (ground that can’t be seen over the top of the hood) when wheeling.
You think this would be easy to find considering the number of MFG’s with rearview mirror cams out there, but I could only find one company that had a system that would work (matching waterproof externally mounted cameras that could be tied into a rearview mirror camera, not a dash mounted cam). Unfortunately, it took a lot of digging, many calls/emails and required me to do some additional firmware changes once I received everything.
I will also use a third matching waterproof externally mounted camera on the rear bumper (centered) and it will be tied into the factory dash mounted screen. Another aftermarket journey for all the needed items, as I did not want to use the bulky Ford factory cab chassis backup camera.
I’ll take pics when everything gets installed.
For now, it is: get it in the shop, test it to see if it will work, dry fit it 10 times (hopefully only 10 times), order all the remaining items that you need now that you know the part/parts you just ordered will work, do some more rounds of dry fitting now that just about everything has arrived and finally.................., put it all on the shelf to install it at a later date (a muuuuuuuuuuch later date). What a Fun Game they call building a prototype expedition vehicle.
Sleep Number Mattress:
I will be running a queen size Sleep Number Mattress in the Rig, so Erin and I can have our own cozy sides of the bed. When I initially did all of my research, I based it off of the combo air pump/control unit I saw in the store for the model/mattress I was interested in, as well as the type of fittings that came on the hoses (I needed 90’s on one side of the hoses as my mattress will sit directly on the composite-no bed platform).
Well, low and behold, they change the pump/control module and hoses depending on what mattress you choose, whether it is comes on a base platform, ……… etc. I can’t tell you how many hours I spent on the phone trying to get the control unit I saw in the store, as well as the associated hoses with 90’s on one end. What they shipped was different. For me, it mattered, because I designed my bed area specifically for the pump/control unit that had the hoses coming out the end of the unit, as opposed to the side of it. The side hose unit is also a different shape and larger (and wouldn’t work for me). If anyone goes the Sleep Number (SN) route and has limited space, know there are two different style pumps.
I also share all of this because SN has a mandatory $250 shipping fee, even for just a glorified air mattress (and no you can't go pick it up from the store either). They do have a satisfaction guarantee (full refund, no questions asked), but what they don’t tell you is it does not apply to the $250 non-negotiable shipping fee. Hence, why I just didn’t return everything and had to spend hours (maybe 5-6) trying to find someone that knew anything about their products.
Just trying to save anyone who is going the SN route some potential future pain 😡🤯.
Vance Vanz
Grey Water Tank & Winches
Fabricating the grey water tank frame.
I have a super tight space in the grey water tank compartment, so I had to get creative. My original idea would not work ☹️.
I ended up having to build a frame that had two separate brackets, with some additional bottom cross ties. One side of the frame will need to be installed (bolted to the camper), then the tank will be slid inside it and the other bracket will sandwich the other side of the tank. I also had to use Riv Nuts on one of the brackets, for the cross supports, because there was no room to get a hand/wrench/ratchet on a nut.
Winches:
I don't want to start the "fuse, or no fuse a winch?" debate, but here we go 🤫😁. I'm running fuses and isolation solenoids for both the front and rear winch (Warn 16.5Ti's) that will be wired into one of my upfitter switches .
Some info that may be helpful for those who want to run an isolation solenoid/contactor for a larger winch (upwards of 500A).
I wanted to go with a reputable marine grade solenoid/contactor for my very expensive winch. I looked into Blue Sea after checking out what appeared to be the only other available options (Amazon ones that may be hit or miss and who knows if they are actually rated for 500A/the stated ratings). The Blue Sea ones were pricey and I was having some trouble just taking my medicine. So, I started digging and making calls to the engineering departments as opposed to the sales departments.
Come to find out, Blue Sea just buys EGIS contactors and rebrands/labels them. Technically Blue Sea may have something built specific for them, but the option direct from EGIS had higher ampacity ratings and cost less. I was also able to find the EGIS option for the same price as the best rated Amazon option. Sold to the man who likes finding better products cheaper.
They are compact little suckers!
EGIS Contactor, 250 Amp, 12/24 V, Sealed (7021B)
https://www.egismobile.com/shop/7021b-contactor-250-amp-12-24-v-sealed-5449#attr=
NOTE: Although it comes up as a 250A solenoid/contactor (when doing online searches) it is a 400A continuous at 4/0AWG and 500A max for 5-10min. Since I'm running 4/0AWG and should never be cycling the winch on for longer than a few minutes at a time, I have a 500A rated solenoid/contactor for a reasonable price. A quick search will get you pricing lower than the associated link.
Fusing a winch. Since I come from a technical trade background (electrical being a large part of that background) electrical circuits get fuses/breakers/protection. It's that simple for me.
I've got plenty of room to mount the fuse holder for the rear winch, but under the hood for the front winch was a different story. The only place I could find that had some room, and made sense given my wire route and location of my solenoid/contactor, was on the battery bracket.
I'll weld the base plate to the battery bracket and get it off to powder coat at some point. On to the next project.
Vance Vanz
Fuel & Water Fills (Housing & Doors)
Here is my initial attempt at getting the fuel fills sorted. Water fills are fine, but the fuel fills are no bueno 🤨.
IMG_2206.jpegIMG_2207.jpegIMG_2264.jpegIMG_2266.jpegIMG_2268.jpegIMG_2270.jpegIMG_2272.jpeg76422542083__653D63B7-741D-4880-8D7B-771DB9782867.jpeg
There were also several late night trips to a closed gas station to test all of this with an actual gas pump nozzle.
My fuel fills will be on the side of the camper, fuel lines ran inside of the camper, like ER. I have a very tight space (I think less than 5"s-it's been a while since I was on this project) to get the housing and filler neck to fit at a 90 degree orientation to the side wall of the camper. Long story short, I'm going to have to revisit this.
I think the answer will be to cut and re-weld the filler necks at the exact angle I need. I had other pressing projects, so this went back on the shelf. The crap I'm having to do to get this this build off the ground is insane 🤪.
NEXT!!!!
Vance Vanz
Heating Pads & Surfboard Rack
I told you we were going to jump around 🤡. Who would have thought heating pads and surfboard racks would be in the same post 🥸.
Grey Water Tank & Battery Heating Pads:
This baby will be 4 season, so I gotta keep things warm in the dead of winter.
I try and test everything electrical when I receive it (within reason). The heaters have internal stats and I wanted to see if they actually worked anywhere near the range they state. I will also be installing separate inline temp sensors/cut outs to tighten up the temp swing.
I eventually put them in the freezer as well.
Surfboard Rack:
This was the surfboard rack someone was nice enough to recommend in one of the initial responses to the build thread. Thanks again for that recommendation, if you are still out there. I finally pulled the trigger on it and sorry it just happened to be SEVERAL YEARS later. I'm a slow worker 😉😆!
After a ton of research, this was the best lockable surfboard rack I could find that could be (for the most part) universally mounted. I also had to just buy it, in order to get all of the specific dims/specs on it to see if it would work.
The closest thing to an adventure I've had on the build. Some day, some day 😟.
I needed to be able to store a long board and a fun board (stacked and in their bags) on the roof. My short board will go in the gear locker with the MTB's. They just fit 🤙.
I also took all of the preliminary measurements to figure out how they will be attached to the roof and the exact spacing everything will need to be. It's going to be super tight on the roof. I was originally going to go with basic round cross bars, which would have been super simple, cheap and low profile, but the locking options (locking straps) were not as good of an option as these. I needed something more theft proof than straps that could be cut with a basic pair of wire cutters.
The only negative with these racks, compared to the cross bars, (in relation to where the boards will sit on the rack), is they are wider. The arms will place the surfboards further out into the walkway on the roof, which was already tight/small to begin with. I'll revisit some of this when I start designing the slide out solar arrays.
Vance Vanz
Heat Shielding the Gas Tank
I didn't realize the time :oops:. My last post before I get my butt to bed :sleep:. I have a long day of designing tomorrow. Hopefully my gramar and speling have'nt been atracious :ROFLMAO:!
My little rant...........
I'm always surprised to see when builders (the professionals-I promise I won't name any names) extend/re-route the exhaust pipe on a build, the exhaust pipe ends up being far closer to the gas tank than any OEM section of pipe and they don't heat shield the tank (Especially, when the factory heat shielded a portion of the tank).
OK, rant done now.
Believe me, this is the last thing I wanted to do on the build. I have so many other projects that I need to complete that are more important. I could have just said screw it, and buried my head in the sand, but I'm unfortunately not wired that way. So here we go with the task I think I least want to do on the entire build (besides filling pits and sanding of course).
To all of those damn tasks you just DON'T WANT TO DO 😫.
Get the gas out of the tank and try not to blow yourself up while doing it 🤓
A little safety net in case it doesn't want to play nice and stay on the floor jack for the duration of the ride.
Not so bad. But, why do I hate simple tasks like dropping a gas tank just to install a small section of heat shield on it, SO MUCH?
Should I just slap a large rectangle on the tank, press it down and call it good, or take the time to do a template.
A template it is.
I'm going to make this fun and do the entire thing with one continuous piece.
I also foil taped all of the seams (not shown) just to be extra sure everything stays
The details that you will never see, but you know are there 😊
To the completion of the 3rd highest ranked thing on the build that I hated doing the most 🥳
Who said this wasn't fun?
Until next time. Night, Night!
gp01
