The Wanderers build
superbuickguy
A few on here know me personally, and likely remember me as the guy with that huge dog at the NWOverland Rally.
I was crushed the weekend I went to my first Optima challenge (2021) because I lost my English Mastiff 'Buick' he was only 6 and got leukemia.
there will never be a replacement, but my Lab Luigi needed a brother - so we got him another English Mastiff
Meet Samson.
by way of comparison (size). Buick weighed 18 lbs at 10 weeks and maxed at 200 lbs at 4 years. Samson weighs 17.4 lbs - Samson's dad is a svelte 200 lbs and a good 4" taller at the shoulder. We will have to work on keeping him svelte but likely he'll weigh between 220 and 250 at 4 years old.
right now, Luigi isn't sure about the new guy - but the new guy brought a ball to him and the look on Luigi's face was "okay, he'll do"
and I may yet go to the rally this year. it'd be nice to socialize him among such nice people.
(Buick at the 2018 Rally)
Andrew_S
Such an awesome mix of projects and skills. Love this build thread.
What's up with the C3 - road course set up? - I must have missed the details.
superbuickguy
It started as a 1976 C3 Corvette. Under it is a 5th gen Corvette front suspension and 5th gen IRS from a Camaro. Has 295/30zr19 fronts, 345/zr20 rears. Powered by a BBC 427 and has a Tremec TKX trans behind it. Dakota digital dash, more space was created inside by moving the rear firewall back.... I race it in AutoX, HPDE events and Optima Challenge....
superbuickguy
for unknown reason(s), the turbo doesn't have the output it should have. Current test, is the wastegate stuck or held open
thus the first step is clear a space to work - I need that step.
pull the exhaust off the back and look
which I did and nothing is hanging it open... think next up is tie it closed
superbuickguy
continuing the same thread
I wired the wastegate closed... best was about 9 psi... same turbo on my other 6.5 td is limited to 11. It was at 20 the first time I ran it....
was going to put the other controller on it, but that makes no sense right now.
it might just need to be run in more - so I'll leave it tied closed and drive it a bit. I figured out the vague center steering. The nut on the steering box wasn't tight... still seems a bit dead in the center but it's a lot better.
next on the list of fixing... tach doesn't work.... this tach, and no idea what it is so I'll have to probe wires to figure out the wiring
for the new tach
the good news/bad news. great stuff is great for holding gauges in place.... it's also terrible to try to remove without harming things (didn't harm things)
Samson was having a rough day....
and in randomness, the sign is gone which means I'm getting closer to closing that shop chapter of my life
back to the blazer... I can see why the speedo isn't working, I'm missing a piece
superbuickguy
the tach does something... woo?
certainly not woohoo
the alternator is definitely putting out a waveform that the tach should recognize
but no
just the initial setting... time to call the maker
Also, need to trace a new diesel leak (that seems to be coming from the valley again)... grand.
I have tomorrow off - hopefully I can spend some quality time on this... whether or not I can is a good question because I have several other projects that need to move forward (such as replacing the vacuum pump on the Suburban)....
superbuickguy
So the gauge is at Speedhut to figure out what happened.
mostly I've been moving, but tonight got to do fun rather then maintenance... what do I choose to do for fun? align a window. I know, I know, I should slow down - does it help that it took me 2 hours to complete?
first problem was the inner seal wouldn't stay attached to the door panel, a couple rivets and win
and window finally aligned.... what a pain
and I still say my tractor was the best tool that I've ever bought
ExpoMike
Curious where you are hooking up your tack to the alt? I have a Speedhut diesel tach in my M1010 and it is hooked to the specific "R" terminal on my medium duty size alt. Most automotive alts don't have this terminal.
superbuickguy
Mine has the terminal because it came from a civilian H1. What is interesting, though, is everyone says it's the white wire that is the signal and it's not with this aftermarket plug (which means, trust but verify).
Thankfully I have a tester that will tell me whether or not there is a square wave signal (which is what the tach needs to operate). It also made for a much shorter conversation with Speedhut.
The picture shows the square wave signal the R terminal should be putting out.
superbuickguy
also a plug for this power probe maestro tester. Most electronic controls in cars these days rely on a signal from the computer to operate. Gone are the days of powering/grounding a motor and having it work - the computer tells it whether or not to work and that's done with a signal that looks like what's being read here. With the Power Probe Maestro, you can generate a signal to test computer controlled devices.... not used often, but when I do, it's irreplaceable.
Petersmithinak
