OVRLND CAMPERS ONLY : Post your OVRLND Camper build here or a link to your build thread to inspire others!
dirtnsmores
I have State farm and had it added to my policy in OVRLND's parking lot while they were installing my camper. I was insured for $3.30 a month before we even drove off the lot!
I'll post my current build iteration soon, it's going slow as we find what we like and don't like.
That's a great price. What did you tell them to add to your policy and how does it look on your actual statement?
montechie
Guys! Quick question about tire rating and the weight of these builds. For a truck like a 1st gen Tundra, 350lb camper with a few hundred pounds of gear and build... Would you recommend I stick with e-load 10 ply tires or try out some 6 ply c-load tires? I currently run 255/80/17 E loads and they've been great, but I'm looking at 255/75/17 c loads in the same exact tire that are lighter. They're a half an inch shorter, 32.5, which I'm fine with. Trying to lose a little bit of weight, height, and rotational mass. Not too worried about sidewall punctures...
How many of you are running? C- load, e-load, passenger rated tires? What size truck do you have? The first gen Tundra is considered a full size truck, but it's about the size of most modern-day midsize trucks.
My C rated Falken AT3Ws have handled my Gladiator Rubicon's weight and camping load out fine, and that's over some good rocks/trips etc. I have about 35K miles on them with the camper. For a mid-size the Gladiators are fairly heavy for a mid-size (5K-5.4K lbs). Usually where I feel the difference is cornering, not horrible, but the stiffer E tires rail a bit better. I appreciate the Cs more off-road though, much better compliance on rocks and deform better at low pressures for snow.
Cs may reduce weight, but if you were willing to switch tires another brand/model can be lighter in an E, depending on what you have now. KO2s or Cooper AT3s Es are lighter than my C rated Falkens.
Spencer for Hire
I like E's to avoid squatty potty and sidewall blowout.
Double Down
I used carpet squares and 3M spray adhesive over rigid foam as well. They have held up fine in high temps
(and very cold temps) and I have several things Velcroed to them as you can see in the photo.
@KellyM It looks like you have a Truma furnace mounted on the wall there... Any more pics of how you have that mounted? Did you install it yourself? Or was it done by an installer?
KellyM
Here are a few photos of the furnace. It is mounted to the framing. A friend of my did the install. He is an authorized dealer for Truma. Check out AT Overland toppers for similar Truma installs. The Varioheat furnace works well by the way. I slept in 12F and was comfortable.
Double Down
View attachment 887322View attachment 887323View attachment 887324View attachment 887325
Thanks for the pics, appreciate it! Looks like a great spot to mount it. Is your buddy the Truma dealer willing to do other installs?
dstefan
Motafinga
Edit: my tire of choice is the Toyo open country at3. They've never left me stranded and have plenty of good sizes in the more narrow range.
I have the Toyo OC AT3 as well in a C rating, good tires so far. I think an E rated tire is a bit overkill on these lighter camper setups for how much harsher they ride and the MPG penalty. My rig weighs about 5100-5300 lbs depending on what I'm doing. 1st gen Taco
crismateski
American Adventurist
After the aforementioned washboard pounding we experienced in Saline Valley in December, I got home and set out to improve the suspension on our Tundra. I started by weighing the truck and determining the camper weight to be around 1400# with a full tank of water, and that 2-3” of lift over stock would be the sweet spot that would allow sufficient wheel travel for my adventures. I contacted Alcan springs for a custom progressive leaf pack and Ubolt flip kit. They were easy to work with, and built exactly what I wanted. Once installed I measured my suspension travel and called Accutune suspension for a custom valved set of shocks to compliment the springs. Due to the weight of the camper, they suggested the Fox 2.5 Performance Elite series of shocks. It took a while to get the pieces, but now its all installed it’s a huge difference in rear suspension performance! The Ironman FCP lift struts in the front will be replaced next.
View attachment 880007View attachment 880008View attachment 880009
I really wish I had thought to have the size of the doors offset like that.
V45W_Proto2.5
