2007 Silverado - Buy Once, Cry Once: 1-tons, 40's & a Custom Camper
Andrew_S
Thanks, hoping to get more done quicker, but it's getting there.
That chassis is for the red/black truck. I started on it a few years ago and then it got sidelined by the SAS for our blue truck, kiddo #1, now this project and likely kiddo #2. One day I'll get around to finishing it.
Sneak peek at this coming weekend's project:
Kingsize24
I'm jelly! 😂
frojoe
.......I've been considering a couple of options for the accessory drive, dual alternators or maybe even a york 210 and a single big alternator. I'm worried the ARB won't have the output for the tires. Leaning hard towards selling it and going the York route.
Which ARB do you have? For what it's worth, my ARB twin does a great job at filling my 40's from ~22psi to 40psi surprisingly quickly.. Like I have to be checking the tire pressure pretty quickly to make sure I don't overshoot 40psi.
Andrew_S
^ It's the twin. That's good to hear. I'll have to do a test with the identical unit in my other truck and time it. During hunting season (6-8 weeks) I find myself airing up/down almost daily. That's driving the desire for a really quick system.
Quick visual I put together of the arb line up vs york.
Started cycling/trimming for the tires on Saturday, almost full droop in this photo.
Far less trimming required than I expected. Definitely won't clear chains in the front under full compression though...
At least I'll be able to max the steering out to the stops
Took a break from that and extended the rear wiring harness to compensate for the stretch.
Perfect little home for this junction. Now all the rear lights/harness will go with the deck and it's a single plug to remove it.
Power steering cooler installed. I think I'll revisit this and the trans cooler in a few years and put in additional cooling. Time will tell on that one.
Next big job, tackling this leaking axle seal.
No idea why but this was leaking immediately. It looked perfectly sound. It must have got twisted when I was inserting the shaft.
The short side came out with the shaft...
Ditching these 2-piece seals and going with the standard 1-piece old school design.
Started on the hydro assist and stopped quickly. Originally, I wanted to position the ram like this:
However, packaging was proving to be incredibly difficult. So I'm going this route, which means a new diff cover because I don't want to attempt welding to this cast Yukon unit.
Had a setback with the rear driveshaft design, apparently a steady bearing that mates to a 1410 flange for a double cardan is not a common piece... Going to revisit that tomorrow and finalize the bits and pieces with the shop doing the work.
Also, I can't for the life of me decide on tail lights.
Kingsize24
Maybe check out some Australian lights. They have such a huge selection since they use trays there way more than here. The shipping cost is usually surprisingly cheap as well.
Andrew_S
^ I've looked at so many ute trays haha, the maxilamps that come on the Norweld decks are one of the nicer options out there. I think* I've found a pretty rad solution for the rear lights, I'm guessing/hoping it's the first time it's ever been done before. I have a few questions for the company before I can proceed, but if it works out, I'll be stoked.
Quick evening project, the stock wheel was starting to get soft and gummy.
Picked this from the junkyard for $30. Nice little upgrade. It'll look more in its place once I do the dash trim as well.
Also picked up some 2" rigid wall fuel line, pricy stuff. I need to get a properly angled fuel filler neck, but this is roughly where it's going to be located. It made the most sense to locate it here, I can get a good amount of vertical drop to the tank, and this corner was already compromised for a box by the lift pump. I've done more research than I care to admit on fuel filler hose locations, my rough understanding is you want a quick drop immediately at the inlet and then it can level out and it won't backflow, hopefully this is enough.
I'm waiting on a few key parts to come in the mail later this week and next week. Progress is going to be metered until those items arrive.
NevadaLover
Forking Icehole
I have installed a bunch of flatbeds and workbeds, if you make a jig for the fuel fill hose then heat it and cool it a few times with a heatgun, it will mold to the shape you need, patience is the key.
Your trucks are fantastic to watch develop and I for one enjoy your posts, thank you for the hard work and I hope you and your family enjoy many years with them.
We had a dump bed OBS F350 for a while. The front filler was set up similar to your picture, and it worked well. The rear filler came out flatter and was really annoying. It had to be filled really slowly, so it wouldn't trip off repeatedly. I think what you have will work fine.
I'd like to build a flatbed for my Dodge, and I've been picturing the filler mounted on the headache rack and running through a top bedside box. I guess you considered that but already have plans for that space?
Andrew_S
^ Thank you, that's reassuring to hear. The camper will butt right up to the truck, so there's no need for a headache rack. Otherwise, I would definitely explore the headache rack option.
Thanks, I'll have to try that shaping technique if it proves to be challenging. Appreciate the good words. It's challenging to find the light at the end of the tunnel some days.
Started up on the rear of the deck. This is a delicate dance of packaging and proportions. A lot of head scratching and revisiting my right angle trig.
All tacked up
Once I get this populated with tail lights, reverse & license plate lights & a creative idea I have for a spare tire mount, it's going to look a lot different. It's a bit challenging to visualize it with the side boxes but I think it'll really come together in the end with everything completed.
andy_b
All tacked up
That tray (and the rest of your work) looks awesome. Are you going to integrate a bumper into that rear skirt somehow? I would worry that anything more than a low-speed nudge could be a real headache. I know you integrated the hitch and winch mount which would provide protection in a bigger impact. I lack your fab skills but the off-the-shelf tray I got had a similar skirt that I removed and replaced with something more substantial.
35xj
Awesome build! I was just lamenting to a friend yesterday that overland in general and this site has become a bolt together pavement princess fashion show. it’s awesome to see somebody actually BUILD something!
Awesome job so far. Can’t wait to follow along!
Andrew_S
35xj,​
Thanks for that . Definitely a lot of time and effort is required as soon as you start making your own pieces...
I've got nothing against the bolt-on bits, if anything, they supply me with a lot of great ideas I can use as inspiration for the custom stuff.
This rear tailboard is fairly skookum. It's constructed out of .188" wall aluminum tube tied welded directly to the .250" wall frame, and butts up directly into the hitch and winch cradle. I plan to leave it as is, there is no doubt a rear impact would tear it up as it's only aluminum at the end of the day... It's all a balance of aesthetics and function for me. There are some other items on the rear, particularly a spare tire carrier that will completely change the back end quite a bit.
Well finally after looking at thousands of North American flat decks and Australian ute trays and becoming far too familiar with the common offerings, I've finally settled on rear tail lights.... and it's something that I don't think has ever been done before? The Glohh Gl-2x lights, these are designed for a defender.
They have a flat back design and rather simple wiring that makes them perfect for a deck configuration.
Here's a better visual.
These fit the theme of the build (crying), but they were cheaper than some of the more common LED offerings from Grote, Knapheid, etc, and they look a hell of a lot better in my opinion.
Along with making great-looking lights, this company also appears to spend a fair bit on visuals for advertising:
Looking forward to getting these mounted up.
Andrew_S
Got a little bit more checked off the list this weekend.
Mocking up the lights
Wiring up with the stock harness
Took my time and did this right. Everything is loomed and easily disconnects at the light and at the rear panel.
Next up was putting this front axle back together
Hydro assist mount
New seals installed
Fingers crossed it's sealed this time...
Tight packaging with 17's on the Super Duty axles
It's nice to have this thing back on it's own wheels again.
Now it's time to finish up this deck.
Andrew_S
It's been a busy week but I haven't moved the needle much on this one.
Started stripping out the old remaining steering components
Finding a home for this big reservoir in this already congested engine bay was definitely a challenge.
Embarrassed to admit how much time this took to fab up and get just right, the little things no one ever sees.
Thankfully, the Silverado hoods have a bit of a bulge in them, otherwise this unit and the York 210 would never fit... @1stDeuce - looks like I'm sticking with the high hood.
Integrated the breather into the bracket as well, all painted and ready for final.
Received this order for the flat deck boxes on Friday. All stainless hinges and compression latches, ended up sourcing them locally for far less than online.
I then lost my remaining days with daily driver maintenance. New control arm bushings for the '86.
New 5100 struts, steering rack, K03's and trans flush for the wife's 4runner
Lastly, scored some new to me tools on marketplace yesterday for a song.
V45W_Proto2.5
