Land Rover Ideas for Grenadiers
jscherb
Places to carry a second spare? For some expeditions, I like to carry a second spare tire. For example, when I did the Dalton Highway up to the Deadhorse on the Arctic Ocean, I carried an extra because word is that there's lots of metal junk along the 250 mile unpaved stretch from Coldfoot Camp to Deadhorse. I did get a bolt through one of the tires, but it held air until I got back to Fairbanks and I changed it there. This photo was taken atop Atigun Pass on the Dalton Highway, it's July and it's snowing. I've got an extra spare on the roof rack and also jerry cans on either side of the Jeep because there's only one fuel stop in the 500 miles from Fairbanks to Deadhorse:
On some British military "Wolf" model Defenders, the spare is mounted on the side of the hardtop. Not sure if this makes sense for a Grenadier.
A more common place to mount a spare on a Land Rover is on the bonnet:
The Camel Trophy Defenders, part of the most difficult offroad challenge in the world, were fitted with 7.50x16 Michelin ZXL tires. There were two spares, one on the rear door and one on the bonnet. These are significantly narrower than the tires on the Grenadier:
Not sure that's a good idea either - the Grenadier hood is higher than the Defender hood and the tires are wider than many Defender tires, so it migh obstruct vision too much. And I wonder if the Grenadier hood is reinforced enough to hold a heavy spare. Land Rover hoods for carrying spares have a recess the tire sits in, and their reinforced underneath.
Another Land Rover option; I haven't seen one of these for the Grenadier yet...
Another dual spare carrier, this time on a Discovery that probably is traveling far from the nearest place to get a tire fixed.
jscherb
Mounting solar panels on the roof is fairly common, here's one that looks like a flexible panel:
The solar panel on this series Land Rover is mounted under the front of the roof rack and slides out for use:
I liked that idea so I implemented a slide-out solar panel for my roof rack...
Deployed:
Stowed:
It works very well. The Grenadier reports that my battery is now usually in the high 90% state of charge, and in the wild, the solar panel keeps up with the demand of the kitchen/fridge.
jscherb
A project I did that was inspired by this small piece in a Land Rover magazine:
Seeing that in the magazine inspired me to sew my own, I made a two but only one is hanging from the edge of the tent in this photo:
At first I used "awning rope" to hang them. Awning rope is a rubber extrusion that has a bulb that slides into a channel and a flat edge that can be sewed.
There's a channel on the bottom edge of my RTT (and many other RTTs) which accepts the awning rope:
Later I made a changing room that hangs below the tent and to hang it I used awning rope to attach it to the tent base. Since that meant that the awning rope channel was no longer available to hang the shoe bags I changed the bag mounting to snaps. In these photos the tent is off the Jeep and standing against the wall of the garage but you can see how the snaps are implemented.
I know this isn't specifically a Land Rover idea because these are generically for roof top tents and are available in the U.S., but I was inspired by the photo in the Land Rover magazine to make mine. Anyway I thought some might find the two methods for hanging the caddies useful so that's why I posted this.In the one of the photos above you can also see a grommet in the top edge of the shoe caddy, it's there because the tent awning support rod goes into a hole in the edge rail of the tent platform there.
texasnielsen
Outdoorsman
Deployed:
View attachment 890034View attachment 890035
Stowed:
Room for two more that would slide out from the sides of the rack also? Perhaps slide to either port or starboard, depending on which way the camp is set up, shade, etc.?
jscherb
Yes I could add more panels to slide out from the sides but I've been using this same solar panel for years on the Jeeps and it keeps up with campsite demand (fridge, kitchen power, etc.) in almost all sun situations so my experience says another panel isn't necessary. Also I've installed a more efficient solar controller in the Grenadier than I have in the Jeeps so performance is even better in the Grenadier than it is in the Jeeps.
About the need to catch the sun, I designed the slides so the panel can be removed by turning two retainers and sliding the panel all the way out; the panel has ground legs and I carry an extension cord for the solar connection so if the sun isn't optimal hitting the panel up top I can put it on the ground and aim it directly at the sun at some distance from the vehicle if necessary.
And my Grenadier has the factory dual battery option and with that option the auxiliary battery only serves as a backup to the main battery, power is only drawn from it if the main battery is low, so even if the panel didn't keep up with the campsite demand there wouldn't be any problem starting the engine because the auxiliary battery will help if the main battery is low.
A little more info on the solar configuration... the panel is a 100w rated panel from Harbor Freight that I paid about $80 for on sale. It's gone up since then but it's still a good value and can be bought for about $120. It's capable of putting out 23+ volts at 6+ amps in full sun. I use a Victron solar controller which is very efficient; I chose that for several reasons over the CTEK that would have been a direct plug-in to the factory CTEK dual battery controller - 1, CTEK documentation (and I checked this with their support staff) can't support a panel that outputs over 22 volts, 2. It's way less expensive ($60) than the CTEK ($400+), and 3 it has Bluetooth support so I can monitor the performance of the solar panel, the charge current to the battery and the battery condition on my phone.
jscherb
Given the similarity of the Grenadier's headlight bezels and those of the Defender, maybe this project would be useful to keep the headlight lenses clean. It's a nice implementation, it only works when the windshield washer is activated and the headlights are on.
jscherb
This post is a bit off topic and isn't really a "Land Rover Idea for a Grenadier" but it did come from the UK Land Rover magazines and it's more like a "Land Rover Idea for a Trip".
Expeditions... in every issue of the magazines there are articles on expeditions somewhere in the world - many are in Africa, many in Europe, Australia, Asia/South Asia and often in the US. Here's one about Nepal. Land Rovers are used for jungle safaris in Chitwan National Park...
From the article:
We were in Nepal a couple of years ago and Chitwan was part of our road trip but we chose a more primitve form of transport to go into the jungle. The elephants can go places the Land Rovers and Mahindras can't, such as crossing the river in the photo below, which was too deep for a Land Rover and had steep muddy and slippery river edges but it was an easy stroll for the elephant.
We did see a white rhino close up:
Didn't see any tigers on this Nepal adventure, they're fairly rare in Chitwan but we've seen wild tigers, leopards and elephants in the Indian jungle. In the Indian jungle we've used elephants, Mahindras and Maruti Gypsies (a.k.a. long wheelbase Suzuki Samarai) but no Land Rovers.
I'll be posting more expedition articles from the magazines, most of which will detail trips you can take in the USA.
jscherb
jscherb
I posted a few photos of Land Rovers with cargo boxes up top earlier in the thread. I showed a box I use on my rack that I found on eBay. I find boxes on the rack to be very useful.
One option would be to make up a box like the one I showed a cardstock mockup of earlier in the thread:
Or...
Most of the expedition-equipped Land Rovers with roof racks in the magazine photos have boxes on the rack, either plastic or aluminum.
I see plastic boxes on racks in the U.S. from time to time but I don't often see aluminum boxes here. There are a few vendors here that sell them but they're fairly expensive so I haven't seen to many in the wild.
Aluminum boxes, even custom made ones, can be had quite affordably in South Asia. Shops that make aluminum boxes are common in both India and Nepal. I gone into these shops a few times and asked about the pricing; they'll make whatever size you ask for and they're pretty reasonably priced. The problem is that I haven't figured out how to get one home without the shipping of the box home costing too much.
This shop is in the Thamel market area of Kathmandu Nepal, doesn't look like the guy is too busy :). His boxes are painted.
This photo was taken in a different shop also in Kathmandu, there's a sheet of aluminum on the floor and the guy is measuring out a box before cutting. It would be fun to walk in with a sketch and walk out with a custom box. But how to get it home affordably?
jscherb
More on aluminum storage boxes.
Not sure if the pricing is the same with all resellers of these, but I found the 29 liter box on a U.K site for 89 GBP (about $115) and on a U.S. site for $215. I guess that's why they're more popular over there than they are here.
That pricing makes the ones you can have custom made in India and Nepal more attractive, I'll definitely look into shipping costs next time I'm over there.
Another Aluminum Box. Seems like there are a lot of these in the Land Rover world.
jscherb
Another idea from a Land Rover magazine to follow on from my previous posts about aluminum boxes - inner bags for the rooftop boxes. Seems like a good idea for aluminum boxes so gear doesn't rattle around in them or dent the box from the inside.
jscherb
Yesterday I posted a short article about bags for the inside of storage boxes. They were from a company called FlatDog and since I hadn't heard of them before I went to the company's web site to see what else they had. I found this ground anchor:
The only ground anchors I've seen in the U.S. are either Pull-Pal or Pull-Pal knock offs, some of which look a lot like boat anchors, but all of them are bit large and somewhat awkward. This one comes with a storage bag and is quite compact when stored, probably could fit under the back seat of a JKU.
It's a pretty simple device. A piece of 1/4" steel plate with a longitudinal bend in it, 6 stakes which look like they're made from 1/2" steel rod, and a d-ring.
Here's a link to the company that sells it: https://flatdoguk.com/fd-emergency-ground-anchor~750
What do you guys think of this product?
jscherb
Back to the ground anchor topic from the prior post... here's another way a ground anchor could be made - when I'm on the trail I carry 4 aluminum sand ladders. They could be adapted to be ground anchor plates, which would eliminate having to carry a specific ground anchor plate - only the stakes and the bolt-on attachment point for the sand ladders would need to be carried. Here's a quick concept sketch, the red lines are stakes and I've drawn in an anchor point that would bolt to the sand ladder:
I liked the concept so I built one:
The parts that bolt together and to the sand ladder:
I tested it in the backyard; I haven't been stuck on a trail and needed it yet though:
The anchor point and bolts store in my recovery bag and for the stakes I made a separate bag:
This is now part of my standard recovery kit.
