Roaming Lost: x3 Locked 1990 Toyota HDJ81 (80 Series)
roaminglost
Good episode! Did you use a rust converter before the protectant went on? Or does that product have a converter already in it? Dry ice blasting definitely seems the way to go however. I cannot imagine anything else getting it cleaner.
Yea this stuff is similar to por15 but you spray it on instead of painting it on. Looks better I think too.
I should of done this long ago!
roaminglost
Wiring day.. Got some LP9 + S2 SAE fogs wired up. just need to figure out a hi lo switch in the cab for the LP9s
1756083059936-webp.3977718
1756083076542-webp.3977719
roaminglost
Finally have the truck running the way it should. Huge thanks to Technique Vehicle Outfitters for getting everything dialed. The first pump I received was faulty, but ADS took care of it right away and had a replacement to me within a week.
The Wholesale Automatic Transmissions Nomad valve body completely changed how the transmission shifts. Paired with the new ADS Injection pump, the truck feels smoother, stronger, and way more responsive.
Can’t wait to put some real miles on it and see how it does on longer trips.
roaminglost
Got my Carbon Winch installed today over at Offroad Toy Outfitters. Possibly the first Carbon in the states.
Fits in the Cruiser company bumper pretty well. slight mod to make the control box fit with the intercooler
PNWav
