SuperTramp just sent out a recall for all Flagship LT campers about the 30-amp actuator breakers. From the email: "We advise that customers turn off all four 30-amp actuator breakers, located in the top left of the camper’s electrical box, any time the camper’s roof lifting system is not being used. This includes storage, traveling and camping in either the fully up or fully down position.".
They said they're working with Linak on a temp fix, and then a long term fix.
Thanks for posting
@roamie. It's great to see STC addressing this LINAK actuator issue. These are top of the line actuators but things happen. Happy that LINAK is quickly working with STC to address. I feel for STC having to deal with this LINAK issue, but STC stepped up fast and worked this as a top priority.
This is a two-part solution.
The first fix is not a temporary fix, but rather a long term fix that addresses possible water intrusion past the actuator-plug o-ring and onto the actuator circuit board which could trigger actuator movement on their own. This is fix is only needed on the two rear, exterior actuators. If you are getting extensive rain/moisture on and in the interior actuators, then you have bigger problems to worry about! Ha.
The second part of the overall fix is the installation of a timed relay which will cut all power to the actuators ten seconds after they come to rest in either direction. That is similar to turning off all the breaks but is done automatically. When it's time to put the top up or down, there will be an additional three second delay, once the actuator button is pushed, for the relay to energize and actuators to start moving. But, no need for operator to flip any additional switches, breakers, etc. Just use the actuator buttons as usual and the relay will connect power "per use".
For now, everybody please keep those four actuator breakers off (open circuit) until you get both solutions in place. Thankfully the breakers are easy to access and so easy to position on (closed circuit), when roof actuation is needed, then turn the breakers off (open circuit) when complete.
Breaker positions from the PDF:
