2015 Ram 4500 Super Single w/ Bigfoot 3000 camper - $65k OBO
Y-dubs
I’m not certain of the brand without taking a look. I have the rig in storage due to HOA restrictions but will swing by sometime this week to check it out and let you know.
What head unit is that? I've seen some that you can't even see when in the sun and just aren't bright enough. Yours looks to not have that issue.
Great looking rig!
84FLH
Y-dubs;
I have three questions.
What's the overall length and height of the rig?
What's the wheelbase length?
Is the rig under GVWR when fully loaded but with driver only?
Thank you.
Y-dubs
Great looking rig!
I’ve looked for the brand but can only find a model number in settings. It’s AJ002-OB. An android unit the previous owner bought off of Amazon.
Y-dubs
Y-dubs;
Thank you.
The overall length is 27’ and height is 12.5’. I’m not certain of the wheelbase and have the truck in storage at the moment. I will check next time I’m out that way.
I’ve never weighed the truck/camper. The door sticker states total payload of base chassis prior to any alterations to be 7857lbs. The truck has an 11’ CM truck bed Model 1510308 with listed weight of 1260lbs. The camper is a Bigfoot model 30C10.11 with a base weight of 3,511lbs. 32G fresh water tank @8.34lbs/gallon= 256lbs full. No black water bc composting toilet. 52 gallon fuel tank on truck @7.1lbs/gallon = 416lbs full. Let’s say the Hammerhead bumper/winch and tool boxes are another 400lbs - total guess. That totals 5807lbs. Payload of 7857-5807=2,050lbs for passengers and other gear. Again these are theoretical as I haven’t actually weighed them together or separate. Hope that helps!
Y-dubs
Y-dubs;
Thank you.
Finally got back out to the truck to measure the wheelbase. It’s the 197.1” version. The door sticker also lists the total GVWR as 16,500 lbs. GAWR rear is 12000lbs. GAWR front is 7000lbs.
84FLH
Thank you, dubs. Now that's a payload, 7857 lbs! And the remaining 2050 may be enough. Checking back in a few days. Thank you.
Y-dubs
How easy is it to offload the camper?
The camper is equipped with electric happijac camper jacks. Just lower the jacks, loosen and disconnect the four turnbuckles, and drive out from under the camper. It is helpful to have a second spotter when putting the camper back on.
84FLH
Y-dubs;
The bigfoot has everything I'd need for full timing. But I think the overall length and sheer mass of the rig itself would keep me from getting to the places I'm hoping to see.
OTOH, seems like a good deal for a ginormous payload in a highly regarded truck. If it were an extended or single cab it would be nearly perfect.
GLWTS
DFWSFO
