M100 pix of current mods
Tumbleweed
It will be mostly white probably. Thinking between Zolatone paint that looks like white marble, or a white tinted bedliner type. Zolatone is the "trunk paint" that was used in most car trunk interiors in the 60's. Both paints have a light texture to them.
The Zolatone will have to be sprayed on with an undercoat type gun. The other can be sprayed, or rolled and brushed. I am not sure i the Zolatone will need a clear coat or not.
Waiting for warmer weather, my garage is attached to the house and any fumes go straight into the house.
Costs for a gallon of both types paint is similar, within $25.
JJonesee
Zolatone is a good choice.
I have several friends that have painted their rigs with it. Seems to hold up very well. I don't think they have clear on them but I don't know why it would hurt.
Looks good - I like the 2.5 gallon can holders.
ntsqd
Heretic Car Camper
Worth checking into
What I was told many years ago is the Zolatone needs a top coat of some sort to be waterproof. A friend's truck bed rusted under the paint and he was told this was the reason why.
I've no info since then, so things may have changed - or the source may not have known of what he spoke. I'd look into it before committing to that paint.
Tumbleweed
No pics of it. Just moved the outer sheath clamp and redrilled two holes for the u-clamp each side. I am guessing that I moved the clamps about 1/2". This put the outer cable sheath far enough back to work without applying drag on the brakes. You can also get some adjusting room by loosening the clamp behind the brake drum that holds the outer sheath of the cable.
XJBANKER
Thanks I am just exploring all of my options.
zhukoveli
