Buildup my OFF ROAD CNC (camper)
VE2WHZ
Hi i start my tread for build my off road camper
C = carrier (is my name pascal carrier)
N = Noel (name of my wife)
C = camper
is based of 4'x8'
i look look the
SawTooth XL and the Off Road 'Kinda-Sorta
is my camper
first skech
google skech
tire 31 AT
axel 2000lbs
wall (fram is my with tubing 3/4 with foam)
exterior aluminium and checker plate
interior 1/4 plywood
more info later ...
VE2WHZ
Nice design. Looks to be a bit narrow though. How wide is it?
the wide is 48'' interior
the camper is for me or me and my wife ...
for the famaly i have big camper for it :)
the windos is arrival today
on this week end i'm starting the build !!
:victory:
VE2WHZ
next !!
rim
Axel
start
fram
sketch the wall on plywood and make a cut
weld wall fram
1e
2e
see you next day
:coffeedrink:
UK4X4
Looking good- how do you intend to join the outer wood to the frame ?
sealing the corners etc
Depending on the interior and gear you intend carrying you may find a 2000lbs axle a bit weak- clarify on road no issues but off road the stresses are higher
VE2WHZ
i would like to make natch on plywood and welded the frame on sub fram ...
forme the axel is 2000lbs
i would like to my off road with
but is possible to upgrade for 3500lbs on this summer
but this camper is veri lighty ...
i waiting the steel sheet for exterior ...
next week end :coffeedrink:
