Canadian Made Metal Pop-top Trailer
R_Lefebvre
Ah... somebody else using Princess Auto axles. ;)
May I ask where you got those latches and hinges? Princess as well?
swamper
hinges and latch
the hinges and the latch came from a small shop that builds service bodies for the oil and gas insustry. They work real nice, chrome always looks good.
ah princess outo a handy man's candy store.
swamper
lifting
the lifting systemis off of a 60's erra tent trailer, it is madeup out of a 4 piece slider that used pullies and cables, all the cables are an even lenght and run to a centered point where they are attached to a winch for easy lifting. when lifted I will have a room with a height of 6'6". I works realy slick, I did see these at princess auto.
swamper
tenting material
I was able to purchase a old tent trailer with new zippers curtians and canvas, my whole trailer is based on the dimensions of the doner, the tent will pull out to the sides to cover two single beds, while the table folds down for a twin bed. their was also a awning attachment for out the back. I hope to build some type of out door kitchen with that although i so not quite have it figured out in my head.
Xtreme XJ
Thanks... my goal is to also be able to stand up...
I want lift system picts. !!!
Curt
swamper
update
Lifting Mechanism
Rebuilding a 10,000lb winch
Motor Mount with protector guard
support for a slide-out bed
mount with motor in place
slide on the floor showing pullies and cables
torque flex axles did not work - I could not get enough approach angle. went with a drop axel from Princess Auto, reversed the arch in the tube, put the drop up, and sprung under with the springs
finally hooked on behind towing vehicle - `85 Jeep CJ
swamper
floating trailer
Good Idea, how much displacement do you need to float 1200lbs? Just kidding I have a 14 1/2 fool aluminum boat that will sit on top of the camper.
