Elephant Hill "Squeeze Play" HELP! NEED INFO!
LS1matt
So with only 4 days before i start my trip to Moab, I need to know... Does anyone know the width of the narrowest spot on the squeeze play for Elephant Hill Loop? I will be taking my 08 Silverado with a 6 in lift on 35's and was curious... I saw a picture of a H1 making it through, so i am thinking I should be ok. Any help would be appreciated.
Desert Dan
I'm not sure where the squeeze play is but I took a Doge Ramcharger thru Elephant Hill. There were also Suburbans.
LS1matt
It it where the trail get REALLY narrow, Did you complete the entire loop?
Here are a few pics i googled of the "squeeze play"... If burbans and your charger mad eit through i think i should be ok...
LS1matt
It is the height that is an issue. I know a Sportsmobile made it through, after removing the side mirrors.
Thanks!! That makes me feel a little better. I am really not that tall, the FJ's i am going with are taller then me due to their RTT's, but i am a lot wider.
cruiseroutfit
Never heard it called Squeeze Play, just the Squeeze??
You should be fine. As noted the height becomes an issue with RTT's & racks, I can think of at least one roof rack (ah hmmm Paul) that got a bit of touch up paint after moving through the squueze.
Clemtiger84
