Awesome tire pressure gauge for cheap
jaco
I'm sick of crappy tire gauges, and I've always wanted a decent one. I really didn't see the point in spending almost $200 for a gauge, so I bought a high accuracy process gauge on ebay for $30 and spend another $10 on hose and fittings (I actually just had them)... Clamped the hose with some otiker clamps and I have a $180 tire gauge for $40.
Biggest drawback is that it weighs in at 3.1 lbs.
This 0-60 psi gauge has an acrylic lens, liquid filled with silicone oil with an accuracy .015% of the range of the gauge...
I'm basically copying this, just mine cost $140 less, is more accurate and liquid filled :D
http://www.racerpartswholesale.com/...cre_Precision_Tire_Gauge/Longacre_Tire_Gauges
jaco
Strictly a shop gauge, the nice thing is for what I often do from 0-10 psi it's more accurate than most low pressure gauges yet will still work on a 55 psi tow rig tire :D
One could easily build a 2" high accuracy glove box gauge, Wika also sells the rubber protective shells. In a diaphragm type liquid filled gauge you couldn't beat the durability.
Cody1771
we use those guages all over the place here on the ship, that exact brand and type. exept varrying pressure ranges. nice guages, last for ages
jaco
I still have a few of those, some work, some don't. They become inaccurate if dropped- but the biggest problem I have with those is the bleeder mechanism or something else wearing out on them. I should have saved them, I see they are lifetime warranty. I could have sent them back about 7 of those.
jaco
I use one of these, with a real gauge replacing the supplied gauge. I even managed to get a gauge that fits inside of their rubber bootie (not shown, older version had them). They have a bleed-down button on the side not shown, but it is faster to just pull the trigger when not inflating and connected to a compressor.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=41891
I like it, maybe I'll thread this monster on to one :ylsmoke:
Or a proper sized gauge, here's one for cheap.
http://cgi.ebay.com/0-60-psi-2-5-Li...ic_Hydraulic_Valves_Parts?hash=item2a0221fb80
ntsqd
Heretic Car Camper
I think that I have 4 or 5 of these things floating around. One in each of the trucks plus a couple others. They're not a spectacular product, but they're reasonably good. The original gauges are all over the map. I use the replaced gauge as my std for comparison.
