Snow bicycle pics!
skysix
Snow riding
Got any chains for it yet? Used to see many commuters in Yellowknife all winter with them on. Even at -35....
But I'd suggest against trying to ride across Great Slave Lake from Yellowknife to Hay River on the ice road - especially in the spring when the weather is only -5 or so. All it takes is a spring blizzard to ruin your day....
Corey
OverCamping Specialist
What is up with that site?
I get this when I visit it.
This Connection is Untrusted
You have asked Firefox to connect
securely to www.ktrakcycle.com, but we can't confirm that your connection is secure.
Normally, when you try to connect securely,
sites will present trusted identification to prove that you are
going to the right place. However, this site's identity can't be verified.
What Should I Do?
If you usually connect to
this site without problems, this error could mean that someone is
trying to impersonate the site, and you shouldn't continue.
Technical Details
www.ktrakcycle.com uses an invalid security certificate.
The certificate expired on 7/24/2009 11:24 AM.
(Error code: sec_error_expired_certificate)
I Understand the Risks
Saline
A couple from last winter here in the Kokopeli/Mary's Loop area. 5 min. from my house:D.
Blain
Some pretty nice pics. I'd like to get out this winter and give it a try, as long as I can get my bike running again.
Quick question though, what PSI do you run your tires at? Would it be a good idea to air down a little?
Funrover
I love having a trail to myself. The soft snow, crisp..... cold....... air and empty trails made for a great ride. While this area isn't technical by any means it was still great to get out and ride for an hour or so. The views were beautiful (well minus all the neighborhoods) and I think I will start heading back that way more often!
There were a lot of rabbit trails and I believe a coyote trail or two also
Funrover
I always bring a headlight just in case I stay too long. While I didn't need it tonight I called it close!
Check out that temp!
SuaveGunner
