Land Rover Aluminum Wheels vs Steel Wheels
R_Lefebvre
people will crawl past something and the tire side wall will flex and then the rim hits the obstruction and is ruined. There is a lot of torque available at the rim when a truck is crawling.
Well, when I'm done with these alloys, maybe I'll do some interesting experiments. If this is true, it would seem to indicate the wheels are stunningly weak compared to the load they are carrying.
muskyman
they are not weak compared to other rims in fact I have to say they are better then most. I have seen GM alloys that crumpled like a sugar cookie.
The pressure in the tire actually is what supports the weight of the truck. when you contact the rim in a single location the force that would otherwise have been distributed around the rim gets focused in a single location and the rim yeilds.
You dont need experiments to figure that out, just watch them in action and see a few damaged and it becomes very clear.
R_Lefebvre
Have yet to see or even hear of one single damaged rim, but then just about everybody I'm out with has big tires.
Scott Brady
Founder
Ben,
It is just how it works when you move posts from another thread. The oldest post from the group moved becomes the first post of the new thread. No disrespect was intended.
It just seemed like the discussion warranted its own thread. We can delete your first post if you prefer.
tdesanto
...The pressure in the tire actually is what supports the weight of the truck. when you contact the rim in a single location the force that would otherwise have been distributed around the rim gets focused in a single location and the rim yeilds...
This seems to be the best explanation in this thread so far. In this scenario, it would seem that most wheels could suffer some kind of damage.
SeaRubi
well, it's pretty clear to me now that I've not suffered any damaged rims because I'm so willing to sacrifice other parts of the truck, first. :snorkel:
lots of rocks in in the PNW, usually wet. slipping off the rocks is just kind of a given. maybe being aired down more is just doing a much better job of protecting the rim lip?
cheers
-ike
RonL
For me, Steel rims are the way to go for 2 reasons.
1. You can remove the axle shaft without removing the wheel.
2. Being more "dished in" they do not get as much paint damage from rocks.
muskyman
I would say no, airing down makes the sidewalls compress easier and that makes the rim more exposed to damage not less.
The bottom line is you have been lucky and if you wheel enough in rocky places you will damage a rim, thats just how it goes.
I air down more then most people and often run at single digits without bead locks. I am not saying I run that all the time but if I am playing on tough obstacles I am aired way down. That is very different then bein g heavily loaded with camping gear on a destination type wheeling trip. then I am running a pressure that gives the stability I need without the added risk of popping a bead or damaging driveline components.
TW.Adventurerider
Who makes a GOOD aftermarket steel wheel for the Disco 2? I'm looking for 16" x 7" without an insane offset. Don't want to be doing any sheet metal cutting. Help? :smiley_drive:
Adrift
So would the spare on a D1 be considered a good steel wheel? If so I may just get 4 more of them, paint them black and call it a day.
Antichrist
A fair number of people run them. I haven't seen anyone complain about them from a technical perspective.
xander69
