Simon's M416 Build
sgv209
I got the bed on the trailer this evening :victory: and the wiring done last night.
All thats left to do is finish the fenders and renew registration. Oh and some herculiner.
cruisertoy
How much did you pay for the tub to get cut and bent. I'm working with a company in Utah to do one for me. From the pictures it looks like the sides, ends and bottom are all seperate pieces?
sgv209
I paid 650 for the sheet metal on the trailer. 300 for materials and 350 for labor. And yes, the ends, sides, and bottom are separate. The pieces were cut on a water-jet and were absolutely perfect :)
TacoDell
looks real nice !
like the fact you bolted it down with tabs...
think I'll do the same to my M100 so's I can use it fer fishin' :p
sgv209
It's bolted down with the tabs on the outside AND with 7 bolts securing the bottom floor to the cross members. This is from post #16. It shows the mounting on the bottom. Its the same mounting set-up that the M416 came with, just a little beefier :)
sgv209
Here is how the trailer stands now, I am waiting on some bedliner samples before I tackle that project.
I also reinforced my bumper and added a connector and a place for safety chains.
sgv209
I have had a few requests for the drawings I used to get the metal cut, so here they are.
  • M416_Trailer_EXPO.PDF
sgv209
It's been a while since I have made any progress, but the trailer is ready for camping use :)
I just finished putting Monstaliner on the inside of the trailer this weekend, I should be able to start using it in a week or so once the liner fully cures. It is a two part roll on bed-liner that gets its texture from the roller instead of rubber bits inside it. It went on thicker than the herculiner I used on the inside of my jeep, and the sample they sent was nearly indestructible.
sgv209
Thanks! I've spent way more time and money than I imagined I would. All those little things add up quickly.
sgv209
Don't get me wrong, I'm very pleased at how it came out and it was definitely worth it :) Now I just cant wait to go camping
Patrickdenver
Please help me.
I've enjoyed this thread and am asking you this question because I can't find the answer anywhrere.
What size wheel do you use for that 7.00-16 tire you have? I've spent about a month of lurking around forums and sites and just can't find an answer. Those tires are narrow (4.5" for the rim) but I can't find any wheels that actually FIT that tire anywhere. Could you give me a link or suggestion?
Thanks a lot.
Pat
seth.c96
