Locker / Gear setup...
Nikson
If you can afford it there is really no substitute for ARB's front and rear. It is the strongest, most reliable, and flexible setup available for your axles. As long as the air lines are ran correctly and the internal air seal is installed correctly you will not have a problem. The ARB carrier is STOUT. Far stronger than the factory carrier (that you have to reuse with lunchbox lockers). You do not want the carrier or gears to be your weak link. Far cheaper and easer to swap an axle than a munched carrier / gears. Plus you get the street manners that you can only get with an unlocked axle not to mention the better trail manners and less wear and tear on your drivetrain. If you do have an issue with an air line - the plastic air lines are easily trail repairable - and if not - you still have a working vehicle. The locker just won't be locked up. Also, if you order before April 30th and get two lockers - ARB will give you their high capacity compressor and air up kit for free. Buy them on ebay, use 8% bing cashback, and you have a hell of a deal.
I read the thread and wasn't sure if you are doing the gear/ locker install yourself. If you are, and haven't done one before, you should have someone help you with the setup. It's not technically difficult, but having experience along with the many tools that are required to do it correctly is necessary.
As far as 4.56 and 4.88 - there isn't that big of a difference ratio wise between the two. Not like the difference between your stock 3.55 and 4.56. There is however a strength (some may say overblown) issue of the 4.88 ratio when installed in the D30 front. You end up with a pretty tiny (and weaker) pinion gear and is also a little bit harder to setup and get a good pattern from.
Well, my plans are to attend ARB's booth at SEMA2010 this year, and get some information and tips how to install it properly, since they offer a pretty explanation on spot there at the SEMA show...
As far as 4.88., i've figured its not that big of "jump" between 4.56 & 4.88 as you said, but it will provide me with that extra bit of torque in the long run. Also considering doing chromoly upgrade eventually along with the lockers...
eurytopic
Setting up the ARB is the easy part. The gears, however take knowledge (or lots of reading and trial and error) and plenty of specialty tools to do it "correctly".
Like:
Case spreader
8.25 bearing cap tool (or make one)
good calipers for measuring shims
dial indicator with magnetic base for measuring backlash
brass punch
bearing press / puller
setup bearings or a way to make them
inch pound torque wrench (dial or beam type)
yoke holding tool (or make one / giant pipe wrench)
torque wrench that does 200+ foot pounds.
If you aren't going to do 2-3 swaps for yourself or buddies sometimes it's cheaper just to have a shop do it.
Root Moose
I will echo Eurytopic.
I set up a R&P for myself once. I didn't do it again after that. I'd rather drop off the axle and the parts to a pro shop and have them do it.
If you want to do this on a semi-regular basis then go for it. Once the novelty of doing it the one time faded I wasn't interested in doing it again. It's not hard really, just a pita. I seem to get an axle or two setup once every five years or so. I'd rather pay some one to do it.
$0.02
Nikson
$0.02
I have given this much thought as well... (for having a shop do the work)
I've got 2 XJs & 1 YJ that gear/locker work will need to be done most likely, thus I think it will be a good practice to do it on my own (learn it - study it - know how to do it) :)
I think the knowledge & practice will pay for itself over time...
iStan814
