Tacoma Sound/vibration
sargeek
I have 06 Tacoma Sport, and I have an occasional vibration/scound. It feels like I am driving on a rumble strip. Any suggestions?
ECVMatt
Can you tell us more?? When is it happening, what speed, head wind, etc..
There is a problem with the window seals vibrating, but it is more of a sound than a vibration.
ywen
not good not good..
i'm assuming you can feel the vibration thru the floorboard and the steering wheel? and it only does it at a specific speed range?
If so, and if the sound goes away when you engage 4Hi, then your front diff is shot.
sargeek
The truck is pretty much stock, other then the TRD Off Road Wheels and 235/85R16 BFG AT Tires. The truck only has 64K on it so I am suprized about having drivetrain problems. The truck is more of a daily driver, since I still have a TJ for off road adventures.
The sound vibration is definately coming from the drivetrain. Since, I can feel the vibration through the streering wheel, I think its coming from the front end. I usually notice the problem on secondary streets at between 35-45 MPH and I can not get the problem to duplicate through driving style. I have visually inspected everything, but found nothing of significance.
So, I have turned to Expo Forum for a virtual diagnosis.
Overland Hadley
on a journey
Sounds very similar to the vibration problems I had after installing the OME suspension, and the resulting lift of the truck.
I would guess that it is in the two piece drive shaft, at the carrier bearing. You could try dropping the carrier bearing a little. In my case I found removing the carrier bearing drop kit and raising it back to stock made the vibration mostly go away. But that was a very odd solution as most Tacoma's need the carrier bearing dropped when they are lifted.
Try loading the bed up and getting a different driveline angle in the rear, and see if that makes things better or worse.
Let me know what you find.
sargeek
Interesting thought, but the suspension is stock, and the new tire diameter is within .5" of stock. But the feel does seem like a bearing going out.
Overland Hadley
on a journey
I know some people were having this vibration problem even with stock suspension. But if it has been driving smooth until now it does sound like something has worn out.
Jeff Wanamog
Off Road Camper Guy
try this first
Try rotating your tires from front to back first. Don't change sides.
Could be cupping on the tires from Toyotas fine alignment job from the factory.
Jeff
Skim
Jeff
With 64K miles on it I hope it is not the "factory" alignment still. I would start with the simple stuff. I agree with Jeff swap the tires front to back and see if the vibration changes, not resolved but see if it changes. Next I'd grease the driveshaft fittings and see if that changes it. Also-are you applying the brake when the vibration happens ? Have you had the trans fluid or diff fluid changed recently ? Does the Tacoma have a rear LSD ? if you had the rear diff fluid changed and they did not put the LSD additive it will cause a vibration.
sargeek
Weekend update:
The problem did not occure over the weekend, and I put a quick 120 trip on the truck. I purchased the truck used with 27K miles.
It has had all of its routine maintenance done by either Toyota, and an independant Toyota specific mechanic.
The truck has had 2 alignments in the 40K miles I have put on it, and the tires show no sign of cupping after 12K miles. Since I have owned the truck, I have had it aligned twice.
When the vibration/sound occures, the truck is usually coasting, without the brakes applied.
The frustration is that I can not reproduce conditions to make it happen, so it is currently a true intermitant problem.
oskarf150
