#1 Rule of Travel Photography
Wander
I don't know about that Michael, I'll bet they would love to have you take there portrait.
These are great tips, thanks.
The only thing I can add from my time shooting events and social functions is to let your acclimate to the conditions. If your lens fogs it will tough to get the shot.
The minimizing aspect is along the lines of why I was thinking about a rangefinder-small,light but able to produce great images. I'm probably wrong (not uncommon..) but wasn't the famous image of the Afgan girl in the Nat Geo cover shot with a Leica?
haven
"I am currently looking at the E-P2 to downsize even further"
Be sure to check out the Sony NEX-5, too. It uses a bigger CMOS sensor
than the E-P2 does, but manages to be smaller, lighter, and less expensive.
There are only 3 lens choices for the NEX series, but it's possible to use
Sony's Alpha lenses with an adapter.
Delivery of the NEX-5 is expected to start in 6 weeks.
Sonystyle's NEX web page
http://www.sonystyle.com/webapp/wcs...10151&langId=-1&identifier=S_NEX#/nex5Section
NEX-5 review
http://www.imaging-resource.com/PRODS/NEX5/NEX5A.HTM
good series of photos that compare the size of the NEX-5 with
cameras in the same class
Wander
Thanks Trevor, I thought it was Steve but now it will bug me until I figure it out. I read an interview of a photog working for Nat Geo explaining a famous shot they got of a girl in a small village. The photog explained that the people were a little fearful of him and his gear so he took off everything but his old battered Leica and started working his way through the village and was able to get a lot of good images, one of which became famous-which image I wish I could tell you....damn memory!
SunTzuNephew
This is certainly my opinion, but it would be fun to pick a top five or top ten rules of travel/adventure photography.
3. Make sure your equipment is durable and protected. I wrecked a brand new lens in Nicaragua (in a bat cave of all places) because the lens cap was not on properly in the bag. I set another lens on top of the first, and it proceeded to scratch the front element to hell. That sucks. I have also seen fantastic images destroyed because of dust and hairs on the CCD. If you are on a moto, you likely only have one body and possibly a second lens. It needs to be accessible, but also well protected.
What are yours?
Something I learned back when I first started using cameras with removable lenses (an Argus C3 rangefinder) is to ALWAYS have a sacrificial filter (skylight, or 1A) on the lens...when I buy a lens, I buy the filter at the same time, and it stays on forever. Until I scratch/break the filter, which has happened once or twice. $20 filter, $2000 lens.....the math is easy.
And when changing lenses....I hold the body facing down so nothing will fall into it. I have body caps in case I want to store the body without a lens on it, too...
Every Miles A Memory
1. Have a camera with you at all times. This means you need a great point and shoot and a waterproof camera as well. I believe the number one mistake most amateur/prosumer photographers make is not having their camera at the ready, or even with them. You never know when that jaguar, etc. is going to step into view. I have captured some really great images with my little leica p&s.
2. Chase the light This is something Jack Dykinga says. Time your daily travels to put you in the most interesting places at the right time of day. Don't be afraid to wait for the light to develop.
4. Don't shoot everything from the perspective of 6'1". Sinuhe taught me that. He said. "don't shoot everything from eye level" He is right. Get down low, climb up on a wall and shoot down, etc.
5. Take the camera off of green mode. Favor aperture priority and vary your depth of field to provide emphasis or remove distracting elements in the background. Find out what the sweet spot of your lens is. Most are somewhere around F8.
I think Scott's Top 5 say it all, but I'd like to add a few things to what he said
1. Have a camera with you at all times. - This is the most important step in getting photos and good photos. I'd like to add that it makes a big difference to have a camera that can stay in the 'On' mode, but go to sleep when it hasnt been used for a set length of time. I honestly dont know the last time I turned my camera off?
I cant count the amount of times I've reached for my camera, picked it up, fired off a series of shots and was able to capture something that was happening in a split second simply because the camera was on and in the ready mode.
Fast glass really comes in handy here!
To elaborate even further, when we're walking around, or driving, I look at the surroundings and set the cameras controls first. I usually have the ISO around 400, set my aperature to an f/5.6 and put the burst mode on so I know I can fire off a bunch of shots hoping to capture what ever just happened in front of us.
Once I fire off a group of shots, I will then look down to the camera and make adjustments to fine tune the shot and then try and recompose to actually grab a shot that I know I can bring home.
But too many times by this point, what ever had grabbed my attention has ended and if I wasnt able to fire off those first few shots, the entire scene would have been missed.
This also touches on what Trevor and Michael have said that you need to know your equipment like its part of your body. If something just went off in front of you, you need to be able to make those adjustments on your camera to capture it without thinking of it.
Another thing we do which will result in surprisingly good results is to shoot from the hip when in crowded places where bringing the camera up to your eye would result in a different scene or might change the persons reaction you were trying to capture.
This again goes back to having your camera on you, set to the proper settings and knowing your camera like it's a part of your body.
Know which way to point it and have it set wide enough that you're going to get the scene you're hoping for. You can crop the image later and many times the odd angle of shooting without lining everything up perfectly results in a pretty cool shot.
My #1 rule when talking with new photographers who ask why our images look different is to tell them to get a different perspective than they think. Lay down, stand up on something, put something in the foreground to lead the eye and never just stand and snap the photo the way everyone else around you is doing it.
DrMoab
I actually feel just the opposite. Why would you put a cheap $20 piece of plastic or glass over a great $2000 piece of glass?
If you use a lens hood that will protect a lens from most objects that will damage it. Also, if you do in fact scratch or damage the lens, the front optic isn't that expensive to have repaired....compared to the cost of a $2000 lens or more.
I fell into the UV filter when I first started shooting too and it didn't take me long to realize that it was degrading the quality of my photos.
I'm with Ryan on this one.
I dont save up for years to buy some really nice glass and cover it with a filter
Lens hoods are NEVER off my lenses and I've yet to scratch one
XJBANKER
Oh what i am supposed to keep that bulky hood on your lens I am borrowing????
J/K it makes me feel more professional.:ylsmoke:
HB 4X4
If you buy a filter for your $2000 lens, why cheap out? I GUARANTEE that $20 filter is massively degrading your image quality. There is no point in spending all of that money on glass to just cover it up with a crappy cheap filter.
I have a filter on my 24-70 but it's Nikon's Clear NC filter. Cost me about $70, and I have a spare one for when I order my 70-200. I know of a few top pro's who use these, so I know they don't degrade the image quality.
If you buy pro glass, don't buy n00b filters.
photoman
My top two pieces of advice:
1. Whatever gear you have- know how to use it. Doesn't matter if it is film, a point and shoot, dslr, or HD video. You need to know how it works and how to to quickly make adjustments to capture the moment.
2. Don't worry about what everyone else is doing. Every suggestion someone makes can be argued for or against and in what order of importance. Stop talking and start shooting.
sinuhexavier
1. Shoot Less, Compose More.
2. Shoot first, ask questions later.
3. Shoot into the sun or shoot with the sun at your side never at your back.
4. Shoot with a sense of place.
5. Shoot just one more and promise it will be the last. That's a lie.
Henrybrowne
