Antique Land Cruiser on the road since 2003
landcruising
Coen-I would have guessed that they were manual adjusters as the "teeth" on the star wheel are square, rather than angled or "saw tooth" shaped. The auto adjusters would be mirrored, typically. Again, I am not a Toyota expert. With your manual units I would not worry either way.
Have you worked out the tank switching schema yet?
I'm having a nice small manual switch under my seat in my mind.
more images:
The roof got a few layers of paint and varnish.
This is how the once looked.
The balls that direct my life at the moment.
Steering wheel is in and the shifters are connected.
adg
Jim K in PA
Ever forward, Coen. Looking wonderful.
I have a question about your wheels. They appear to be the "old fashioned" split rim style, with the removable outer ring. You must then use tubes in the tires, yes? They are a great system, when properly maintained and handled. I have the same style wheels on my 1973 IH truck. I like being able to change the tire wherever I need to, without a special machine. I am sure others will sing dirges of doom about them to you, but the risk they possess is directly proportional to the disrespect they are given.
Keep the update coming!
landcruising
They are always amazed that we only keep one spare. Almost being frowned upon. But I have two or three new tubes I keep somewhere. If things go really bad, I can change four times. The others keep two tires mostly. Sometimes even only one and one without the rims...
Adventurous greetings,
Coen
Anton2k3
Hi Coen, how's the build going? I'm assuming your very busy trying to get it completed, but we're lacking updates! I've been checking back everyday in the hope there are some new pics!
landcruising
Getting the brake fluid in the system.
Karin-Marijke buys a new window lifter.
Somewhere on a market I came across some old Sika with the expire date neatly covered with a small new sticker with a different date. With the latest batch Sika changed it into an engraved notice on the bottom and removed the side stickers.
"Mr. Zigzag cruiser" Fred from France helps out to get the engine running.
"Mr. Bronco" Jeroen from Asuncion, Paraguay took a plane for a few days to take a peek at the work in process.
I am getting my fill of rivets. A little over 130 go into the roof!
Coen
landcruising
I understood that it was $6000 :wow:
impressive isn't it.
more images:
With the roof it looks a lot nicer.
We ordered a new screen and the guys come over to install it.
Three minutes it takes to get it in.
Esteban and Simon are placing the hood.
Simon is adjusting the hood
Coen
landcruising
and more:
I get the new seat in. Looking great in duo tones.
Simon and Esteban fixing the door rubbers.
To get some space for the new tank we have to adapt some parts of the exhaust system.
This is the place for the dual battery setup.
The mudguards are getting a touch up.
Coen
esh
Fantastic stuff Coen! Are you guys back on the road? I figured you were done since you already had the restoration costs/time posted. Just finishing up or still working on it?
Your efforts and travel are inspiring! If you ever get up to Oregon/USA, please get in touch for anything.
Cheers
Toyotero
landcruising
Coen,
The "restification" is looking good. I'm also following your posts on facebook (I'm Gene who commented on your industrial strength ear plugs [diff breather filters])
Your spring hanger looks odd in these photos... is it out boarded from the frame? They look vulnerable, but that's probably just the photo angle.
http://photos-b.ak.fbcdn.net/hphoto...91689958542_55756113542_4063293_7623817_n.jpg
http://photos-b.ak.fbcdn.net/hphoto...91690173542_55756113542_4063321_3815691_n.jpg
Regards,
It must be the angle from which the photo is taken. All hangers are okay. Thanks though for you concern and all the good lucks from all of you are taken as appreciation.
Coen
landcruising
more:
The spare wheel is going here from now on.
The roof rack is on there again.
Getting a new spot for the logo's. Fixing it with masking tape waiting while the Sika cures a bit.
I bought a nice light for the back.
Coen
