12V plugs & sockets for fridge install
rusty_tlc
Nice find. Using a plug with a spring contact that inherently pushes the connector out of the receptacle just seems wrong to me.
I've been thinking of converting all my 12V stuff over to Power Pole connectors. They are very popular with the HAM community and the de-facto standard for most ARES and RACES groups.
1leglance
I like the Power Pole setups I see in ham rigs....just wish I wasn't too lazy to do that to my setup.
One thing I heard from a ham guy was that you should leave in a reg cig lighter socket for those random times you need to plug in something borrowed.
Corey
OverCamping Specialist
Those look similar to what I used for my fridge installation.
Holds the plug very tight.
LandyAndy
Marinco develop that 'locking' version of the 12V cigar socket I'm lead to believe.... may copies out there as well.
AKRover
So does the Engel plug latch into that recepticle ?
The Sealink ones once engaged have to be twisted 30 degrees to seperate them, they don't just pull apart. Is that the same ?
That socket is the best option for installing the old arbs and engle fridges. You unscrew the socket from the end of the cord which reveals a two blade male plug that then screws into the socket pictured above. The locking cig lighter style are a good second choice.
01tundra
Yep, like stated above, you thread the end off the Engel plug and then the plug threads onto the outlet. Only way it's coming out is to either unthread it or break it completely off.
spressomon
The KKs come with Euro/non-USA/Powerlet style 12V plugs and receptacles. They are GREAT! Secure, high current carrying and positive connection. BMW, et al, motorcycles use this style too.
http://www.powerlet.com/shop-by-product/power-distribution/PWRDIST
I carry both female and male adapters just in case. I wish American vehicle manufacturers would embrace this technology and give up on the 1940's technology stuff :ylsmoke:
FWIW: I've had the Marinco locking style cigarette lighter style 12V plugs fail; there isn't, after they've been cycled a few times, spring pressure to keep them in the rotated and locked position.
LandyAndy
I've used the DIN ISO 4165 type of connectors before, only real drawback is you need to carry an adaptor for all the other things that come with a cigar type plug.... like my cell phone charger, camera charger.... etc.
If I were to really convert away from 'old' tech I'd use something like these :
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=2411159
As it stands the marine plugs & sockets are a good alternative that keeps the flexability of a 'standard' socket, for what is my daily driver after all.
gp01
