1994 Jeep Grand Cherokee
getlost4x4
Found one i'm thinking about getting.
stock, 133K miles, 5.2L V8, Auto (rebuilt at some time), been sitting for 2 years. the engine leaks oil a bit. drive train seems pretty good. windows don't roll down. he's asking $3000 at first until I go over it with a fine tooth comb.
i offered him $500 for it. he is considering it.
Good Expo rig?:elkgrin:
i'm saving jeeps and restoring them.
TOI
Web Adventurer
ZJ's are very capable platforms to start on, and if its running and driveing for $500 i say go for it!
Maximus Ram
Been sitting for 2 years and he s asking 3000..ya, 500 and its a deal. Daughter has a 93 ZJ with the inline 6. Great lil vehicle.
getlost4x4
what axles does the 5.2L have?
i like it. now we'll just have to see what he wants to do with it.
ox4mag
That should be a nice rig to setup for Overland purposes. The ZJ was very underrated in that realm and with some TLC, I'm sure it'll turn out great. And if you get it for $500, keep us posted. Good luck!
getlost4x4
i can't decide between my 78 wagoneer or this 94 GC for an expo rig.
the GC has a lot better parts market for it, so i'll probably just turn the waggy into restoration project. nothing like two jeep projects to drain your bank account.:elkgrin:
Smksignals
I have a 94 ZJ V8 and love it. It has the Up Country suspension and a 2" budget boost. That comes to almost 3" of lift. I have a little bit of sag in the rear with the trailer hooked up (old shocks). I am going to put some Bilsteins on this summer. I put 31's on it and quick disconnect sway bar links. This rig has tackled all the moderate trails I have ran, even pulling the trailer. The CB and antenna install was a snap, GPS's mount right on to the flat dash, nice and clean. Plenty of room for the Edgestar fridge in back, with the spare tire on top of the car. I also have a flow master 40 series on it. I get comments all the time how good it sounds, especially when driving through canyons.
Here's a couple of pics to tide you over. Good luck with your rig !!
ry%3D400
ry%3D400
ry%3D400
ry%3D400
ry%3D400
ry%3D400
ry%3D400
ry%3D400
BigDaveZJ
The 94 CAN be a good platform. The 96-98 V8 models make a little better starting point in my opinion, but it really depends on your plans for a build. For any amount of sustained wheeling of any difficulty, the 93-95 V8 models will need a rear axle swap and a t-case swap. The 35 is a ticking time bomb, and the early 249 cases leave a lot to be desired. They do not mechanically lock the front and rear driveshafts together in 4-Lo. This can become a problem on steep climbs as the front axle can lose power altogether. It is most common to swap in a Ford 8.8 rear axle from an Explorer or even the aluminum 44 out of 96-98 V8 models. For the t-case, a 231 or 242 out of pretty much any Jeep made between 1990 and 2005 will work. You also need to keep an eye on the front driveshaft as most of them are a CV style where all of the slip of the shaft is built in to the CV joint itself. They are very easy to blow up when the front swaybar is disco'd.
The 96-98 249 t-case does lock in 4-lo, and it does give you the stronger 44A rear axle. For a mild build, up to say 33's, they make a solid starting point. My wife bought a 98 V8 ZJ a little over 5 years ago and we put a 3.5" lift and 32's on it and it did VERY well.
Here's some pics of my wife's old ZJ (sold it last week) and mine:
More crawling than expedition, but this will give you an idea of what a ZJ can do:
I've been wheeling and building ZJ's for 10 years, they have their drawbacks, but can make a great rig. Lots of power available (factory V8), and a good amount of cargo room for hauling gear.
If I remember right you were on MallCrawlin a while back for a bit too, go check out some of the build threads there to see what ZJ's can be built to. Also look at any of the Grand Slam forums for trip reports on the various Grand Slams for a wide variety of built ZJ's, WJ's, and even some kickass WK's.
getlost4x4
well, i'll find out tomorrow if he accepts my offer.
i went and looked at it again yesterday. my wife gave me the okay, although she can't see its full potential right now.
i'm going to sell my FSJ. Its a good vehicle, its just not going to work as an expo rig for me.
i know, i go through a lot of vehicles.
