MT Swap into a 92+ E350 7.3?
RocKrawler
Supporting Sponsor
Building my game plan and wondering if anyone has converted an AT to MT in their E350 with a Diesel? Since I'm going to have to yank half the trans out when I do my 4x4 swap to add the t-case, I thought why not pull the entire 5speed MT & T-case from a super duty and get rid of the potentially problematic Auto at the same time. I know some E series vans came with manual trannys, so a pedal assembly could be had, but opinions are welcome on this conversion. Any computer issues? I know I'd lose my uber cool ARB Fridge Freezer center console (an ARB fridge freezer fits perfectly between the front seats of an E350, if anyone was ever wondering - also fits sweet between the super duty pickup bucket seats at ideal armrest level for taller guys, again if anyone was ever wondering) because the shifter would no occupy that spot.
Comments?
wanderer-rrorc
you need to head over to www.oilburners.net and do some reading...its not so straight forward with the diesels..
dual mass flywheels and clutch issues...or getting the right solid flywheel and clutch are KEY to getting it all right...
also check 4x4 vans in google...there are a few writeups on doing them to the gassers (I also know a guy in PA that has done several and can give you his contact info if ya need it)
ujoint
Supporting Sponsor
The Ford vans haven't had a manual trans sometime around 75, so there's no easy pedal fix.
I've come across one late model van that's been done, I think he's a member over on thedieselstop.com. He had to cut & modify the doghouse to get the shifter thru the floor. Not sure if it was gas or diesel.
RocKrawler
Supporting Sponsor
There is a Ford recall for MT Econolines in 1998 because they installed incorrect speedo gears causing the speedometer to read incorrectly, if thats the case there should be pedal assemblies (and clutch master cylinders) available for bolt on - its not something I'm dying to do, but I loved my old F350 with the MT and since auto's dont hold up incredibly well behind diesels that haul weight, I though it might be the opportune time to look into it.
RocKrawler
Supporting Sponsor
ujoint
Supporting Sponsor
That's really really really strange!! I've never seen or even heard of a MT from the factory. I still don't believe it!!!! :)
RocKrawler
Supporting Sponsor
dsw4x4
I am very interested in this I to othought that ford dropped the manual transmission option in the e series van when they changed body styles in the early 90s. The most recent ford van I saw was a 90 with a manual transmission. If some one finds a viable option for installing a clutch pedal I will be one of the first to jump that band wagon. I would love to ditch my auto in favor of a manual. I will do some research tonight to see what I find.
found this1992–present
Fourth generation
Production 1992–present
Engine(s) 4.2 L Essex V6
4.9 L inline-6
302 CID Windsor V8
351 CID Windsor V8
4.6 L Triton V8
5.4 L Triton V8
6.8 L Triton V10
7.3 L Power Stroke V8
6.0 L Power stroke V8
Transmission(s) 4-speed automatic
5-speed TorqShift automatic
fourth gen only came in auto 4 and 5 speed courtesy of wikipedia
third gen came with manual transmissions though maybe I will have junkyard a clutch pedal and see if it will fit.
Derek
dsw4x4
did a quick search on that recall it looks like ford did a typo the recall says econoline however if you read the actual recall it specifies pickup trucks in the vehicle description
1999 Ford Econoline Power Train Recall 98V257000
NHTSA: Action Number: N/A Service Bulletin Number: 98V257000
Report Date:
Oct 14, 1998Component:
Power TrainPotential Units Affected:
350Manufacturer:
Ford Motor Company
Summary: Vehicle description: pickup trucks built with single rear wheels and equipped with 3. 55:1 and 3. 73:1 axle ratio. These vehicles were built with incorrect speedometer driven gears, resulting in a lower speedometer reading than the actual vehicle speed being driven.
ujoint
Supporting Sponsor
I think it's a typo... This info was also there:
VEHICLE DESCRIPTION: PICKUP TRUCKS BUILT WITH SINGLE REAR WHEELS AND EQUIPPED WITH 3.55:1 AND 3.73:1 AXLE RATIO. THESE VEHICLES WERE BUILT WITH INCORRECT SPEEDOMETER DRIVEN GEARS, RESULTING IN A LOWER SPEEDOMETER READING THAN THE ACTUAL VEHICLE SPEED BEING DRIVEN.
Read more: http://www.motortrend.com/cars/1999/ford/e_350_econoline/recalls/index.html#ixzz0wHBCF1wn
And just to be clear, the E series body & chassis changed in 75, and basically stayed the same till 91.
I'm going by Ford tomorrow, I'll see if i can dig something up. I'm curious now!!!
RocKrawler
Supporting Sponsor
Way to burst my bubble guys - I know there's a 91 on e-bay right now with a 4 speed floor shift, but was hoping the MT was available for the 92+. I might have to see if there's a way to work it out
Lockwoodjd
