eXpeditionXterra Build Up
eXpeditionXterra
It Lives!
After dealing with braking problems, it looks like the X is alive again. Had to replace the master with an early Chevy that could push more fluid.
Rear end is finished, fox piggy back racing shocks, custom shock towers, Toby did a really slick job making the lower shock mounts to be low-profile and integrate with the Light Racing jounce shocks.
JamesDowning
Whats the total lift amount... 12"?
How is the body roll in the corners? Did you fab up new swaybars?
attachment.php
eXpeditionXterra
I'm not sure what the total lift amount was. There is no possible way of getting a sway-bar up front. The location that Calmini uses (the valley between the tranny and the engine), is intersected by the third link. Coming from the front is also impossible due to the pitman arm, and the tire clearances.
Luckily, with the coil combo I have on there now, the front doesn't sway much at all. The rear is another story though... Due to the weight I have up top with the tent, the new height of the vehicle, and the flexy deaver leaf pack, the back sways like a drunk monkey. To combat this, we are installing a bad *** rear sway-bar. Should be just about perfect for me with that. And I drive some nasty roads.
eXpeditionXterra
Guys, I am working on the picture issue.. hang in there.
More progress made. Changed spring configuration in the front which dropped it an inch or so, and eats up some sway.
Installed a rear swaybar that means business!
It is really dialed in now.
maXTERRA
Looking pretty BA!
Nice job on the shock mounts too!
This has been quite a build. Now you need to publish everything you've done and learned in this project :)
eXpeditionXterra
It Lives
First time on the dirt in around 2 years. Wow, what a long project. :wings:
More to come soon.
oskarf150
