J8 Expedition Project:
we build this 2 dr CRD J8 for our local distributor as a show/teaser car for professional users, last summer
but since a few months =" sound of silence " nothing moves , we have a demand from buyers but can not get any cars, and a CEE approval seems to be ' mission impossible"
Looks like only Jankel in the UK can get the cars , but only for Mil Sales
So now we build them a Rubi version for professional use :
http://s2.postimage.org/hUwYr-b39b145972d977bad621d3213b81c752.jpg
SSF556
SE Expedition Society
Are those steel wheels 17"? If so will they work on my 2008 Grand Cherokee?
And where can I order them???
alosix
If I'm not mistaken, those wheels are the steel spares that are used on GCs.
J8s run a 5 on 5.5 bolt pattern (like old CJs). Most other modern Jeeps (including new GCs) run 5 on 5. They'd probably fit with an adapter/spacer, but not without some work.
Jason
JPK
I saw those wheels on Mopar Parts' site in the JK section listed as winter wheels/offroad wheels. (not quite sure they are exactly the same...) They are 17".
Here is a link: http://jeepparts.mopar.com/jeep/wrangler-accessories.html
They are also listed under the 2008 GC assessories, exterior. Here is a link: http://jeepparts.mopar.com/jeep/wrangler-accessories.html
EDIT: I tried the GC link and it takes you to the accessories page for the two door Wrangler. To get to the GC, you need to enter your vehicle year and model. That will take you to a menu index, scroll over or click on "Exterior;" "Wheels" will be one of the drop down options. Click "Wheels" and they should be the first listing. Hope this helps.
JPK
x32792
J8-Go or No Go?
Anyone have an update on the AEV J8? Is it a GO, NO GO or on HOLD?
elcoyote
Supporting Sponsor, Overland Certified OC0004
The primary objectives that were laid out for the J8 Habitat conversion are to create a utilitarian set of solutions to storage, water containment, sleeping arrangements, food preservation, cooking and power. All of the solutions that we have created will apply to any JK unlimited. All of the solutions have been defined in stages.
  • Stage 1 means that the solutions preserve the factory rear seat configuration
  • Stage 2 means that the solutions require removal of the 2/3 section of the rear seat configuration
  • Stage 3 means that the entire factory rear seat configuration is removed.
All of the Stage levels are compatible with each other. For example, if you started with Stage 1 and wanted to go to Stage 2 or 3, all of your Stage 1 components are part of Stage 3 and hence all compatible etc. The vehicle can always be returned back to stock if desired.
The J8 will receive a Stage 2 set of solutions. The thought process is to build the vehicle to support 2 travelers while preserving the 3rd seat in the event of traveling in a country that may require hiring a "Fixer" or "Facilitator" to travel in restricted areas.
Our first part of this project is to create additional storage. We focused on the tire carrier. We decided that we needed a secure spot with quick & easy accessibility for recovery gear such as our snatch strap, shackles, winch controller & gloves. We adapted a prototype of a new product by Little Boys Offroad Toys called a "Gearsafe"
The J8 has a different tailgate structure than the JK so we started by cutting off the factory J8 tire carrier plate and welding in place the Gearsafe adapter plate.
Painted to match and Gearsafe installed
And there you have it! 11 gauge tough, powder coated and with a nifty combo lock.
More to come...
SSF556
JPK
Perfect...thanks for the link
elcoyote
Rear seat modification
In order to separate the rear seat and create the 3rd "Fixer" seat as we like to call it, a bracket needed to be fabricated to support the seat pivot and create a new seat belt mount. The bracket still allows for full fold down functionality of the seat and provides the first step up into the Habitat top.
jeepdreamer
Fixer...James Fixer!
Maybe a pedistal mount and a flip open roof to allow the fixer to clear the road with a giant hot water MG from an on board tank? Heehee. Sorry. This is so far beyond my scope to duplicate I am just awed...fantastic work guys. I dig the little safe/spare tire thingy too. Is the combo lock weather and dust proof?
Have you thought of adding fenderwell storage like the old military jeeps had? Lets you use the dead space not ocupied by the wheelwells or gas filler.
AZUnlimited
Great Thread!!
Awesome Thread!! Can't wait to see how the build progresses.
I've been thinking about the "Gearsafe" today and a couple of things have popped into my mind. First, it's a great idea, I love the fact that it makes previously dead space usable. However, it has some "cons"; 1) It appears most after market tire carriers will not work with it? If the vehicle is running stock sized tires, not a big deal. For those running larger tires on a production jk, perhaps the Hanson Tire Carrier could be modified to work with it. 2) I noticed it does not include a provision for the 3rd brake light. Perhaps some tabs mounted to the top of it would be beneficial. They would provide a place for the third brake light assembly on a stock jk to be mounted to, possibly a place to mount an antenna, or additional reverse/rear lights.
elcoyote
The Gearsafe lock is weatherproof but the unit itself is not waterproof. It does have a drain hole in the bottom though
Stay tuned for above wheel well storage ;)
The Gearsafe does have a 3rd brake light provision, we just did not add it because the J8 has none. Since the Gearsafe is technically not yet on the market, there are still some provisions, such as you mentioned, that are still in the works. FYI, I will be mounting one to the AT MJ with a one off tire carrier, so I guess anything is possible. BTW, the Hanson link was dead.
