building the Bullet XV
sarconcepts
O.K. I lied, I just couldn't bring myself to do the last two dressers without any curves! the drawer fronts will follow the curving rails (hey, I'm just continuing a theme already started)
The dresser on the left is on RV drawer glides, sliding out when needed, & out of the way when not needed. Now the hard part, doors & drawers.
For desertpilot, I ordered the windows through quality RV in Springfield, they are 'motion windows' model 1600
http://www.motionwindows.com/prod1600.php
For the skins I relied heavily on randy at harvest valley specialties
harvestvalley@clearwire.net
they are type 5052 aluminum, 050 thickness.
I'd recommend both, but I absolutely would not recommend degaseal 2000 to glue to the base. I originally asked the salesman what the difference was between degaseal in an aluminum can VS. between aluminum & fiberglass, (would it ever dry) & was told 'SURE' but it really hasn't . Use something else.
for gprsdlyt
I designed 'em & had them made custom, specifically to fit my jerry cans.
www.bulletxv.wordpress.com
sarconcepts
couldn't get them in the last post
(& yes, I made a full scale model of them!)
I could probably assemble all the card board mock-ups I've made so far, & have a second Bullet XV!
desertpilot
Thanks a lot for the pointers! I'll use Pro-seal as glue (have a pint here that is expiring from an experimental aircraft project). Wow, .050 of the good stuff, that's one sturdy box you got there! Will give Harvest Valley a ring.
Your cabinets look awesome!
Thanks again,
Holger
Kohburn
looks like a marketable product to me, maybe sell the design to an overlanding company.
sarconcepts
just finished making the last (really this time) toiletry cabinet, real similar to the one in my FWC, but a little sexier. Plus, mocked up some custom bridging ramps I'm having made, capable of holding the bullet's weight, & mounted them up in place to look for any problems in placement. Lastly, changed out the UHAUL's surface roof clearance lights with recessed LED lights.
next.. ..doors & drawers
sarconcepts
This past weekend I made 5 forms out of the old discarded Uhaul wall panels,(nothing goes to waste here) for 5 different parts of the curving cabinets
(each one will be used multiple times to form all 16 doors & drawer fronts), started gluing up the drawer fronts, cut & dadoed all the drawer sides & backs, & cut out all the drawer bottoms. Over the next week I'll glue up all 16 drawer fronts (I've only got clamps for 3 at a time) & sand all the sides & backs.
Hopefully next weekend I'll get 'em all put together & mounted in the cabinets, more likely, I'll have to weave my shop time throughout the holidays (& a couple small trips) & have them all done by new years
http://bulletxv.wordpress.com/
sarconcepts
Nope, much simpler than that, I used 2 layers of 1/4" wiggle board.
wiggle board is a 4x8 sheet of plywood specifically made for bending, it can be bent as tight as a 3" radius, it flopps like a noodle, so you either have to fasten it to something of the right shape, or glue 2 layers together, then it'll hold the shape just fine. It is a bit of a challenge for one person to rip it over a table saw, as it's like trying to rip pizza dough.
I'm not afraid of steaming however, for my only experience with steaming, I had to build an oven big enough to steam a 48' long beam into a 12' radius, but steaming is more appropriate when the wood needs to be structural. wiggle board is MUCH easier.
sarconcepts
The cabinets are coming along fine, man, curves take a while to get just right, but that's the challenge I laid out for myself, getting close to having the inside all made, so I can take it all out again to have the veneer put on.
Lynn
:bowdown: :bowdown: :bowdown: :bowdown: :bowdown: :bowdown: :bowdown: :bowdown: :bowdown: :bowdown: :bowdown: :bowdown: :bowdown: :bowdown: :bowdown: :bowdown:
I have no words.
sarconcepts
just picked up the bridging ramps today, I designed them a chunk beefier than what I could find anywhere else, to handle the bullet's weight
& finished the last of the drawers, those for the dressers
gp01
