oxi
Planning ahead for suspension mods.
Right now I have Bilstein 5100's up front set at 1.75 inches on my 2010 AC Tacoma and that's it running 265/75 on factory wheels.
Looking to run 255/85 on my stock rims and looking into EMU front and rear setup. I plan on carrying weight in the bed with a topper down the road and adding a winch to my front bumper. So I want the system that would handle the weight.
I have a custom front bumper from CBI and swing door rear bumper right now, much heavier than stock junk.
The 265/75 do not rub on or off-road so when I move to 255/85 they should be 0.4 inches narrower and about 1.4 inches taller giving me an additional .7 inches or so of ground clearance. The rear tires go into the wheel well perfectly under full suspension travel.
The EMU gives 2.5 inches of clearance, would it work out with 886 coils and rear Dakar springs? What is the benefit for the add a leaf in the rear with Dakar's?
Will I need new upper control arms for clearance? The issue is I live in Wisconsin so winters are brutal with salt and sand so long term maint. is always in the picture.
This will be an expedition build, not a mudder or desert runner. Slow and steady with the weight I plan to run.
