One of the issues with the trucks, that may be the same with the vans, is the factory shocks are too short. The shocks limit travel, before the suspension reaches the lower travel stops.
When the torsion bars are cranked, the suspension has nowhere to go. Sometimes this looks like it has no effect. There is also a difference in the bars. The heavier bars will respond better to cranking, but they will also ride stiffer.
Try removing the nut on the upper shock mount. Then jack up the van, under the cross member, and see if the suspension travels further down than the shock does.
Hey Photog - I wanted to revisit this comment of yours. Once it gets warmer out I plan to do as you suggest and check the suspension travel with a shock disconnected.
If travel is being limited, then I need shocks that can handle a <3" lift or something like this right?:
http://www.bilsteinus.com/products/off-road/5100-series-ride-height-adjustable.html
The van has 120k miles and the shocks look to be original. I don't feel anything strange but I'm sure I may be due for replacements on all 4 corners.
While on the topic of shocks, it looks like my van has a stem top mount but most shocks for trucks have the eyelet design. It appears I would need a stem-to-eyelet adapter?
	Thanks!
