Bicycle pump?
Splat
Hi!
Silly question....can I use a quality bike pump to pump up my tires? (265/75/16). Not from flat, but say to repump from 20psi to 30psi? (I know it will take a long time) , is it feasible?
cheers!
*Forgot to mention, my pump is rated to 220psi (It's a home/shop bicycle pump, all metal parts except for the handle)
Stumpalump
I have pumped up a tire with a hand pump before and it was brutal. Better than driving on a flat but for airing up 4 tires no. It will blister your hands and wear you out before you get two tires done. Todays pumps are so cheap I doubt they could handle the heat generated if you take turns with your buddy. As a backup or to add a few PSI to other tires on a slow electric pump then why not. You need the exercise. :sombrero:
Edit: I just notice you are going to be using a high pressure pump. That means high pressure and low volume. Thats perfect for a low volume bike tire @ 100PSI but does not have the volume to add 1 PSI to a car tire in 25 strokes. That a guess but I bet it's a good one if not more. Go lower a tire to 28 and bring it back to 30 and see what I mean.
eric1115
Possible? Yes. Practical? No. I've gone from low (<10 psi) to less low (~25 psi) in a ~225/50/17 car tire so I could get to a tire shop, and it would have been faster to get the spare out of the trunk and change it. That was with a shop quality pump; faster than a Silca style but still a ~160 psi pump.
htek
thanks guys! Will look into air compressor then ARB?
There are a lot of decent compressors out there from $50 to $500. What you need depends a lot on what you intend to do.
For example, on my "rockcrawler", I run both an ARB compressor and a engine driven compressor. The ARB runs lockers and the belt driven compressor is for airing up tires on multiple rigs from ~8 to ~30psi. If you (like me) frequently air up 12 large (35" and up) tires at a single time, then you will need a very capable (an costly) compressor. However, I highly doubt this is what you are after.
On the other hand, for my daily driver and more "overland" oriented F250, I bought a very affordable Viair 85p. Airing down my tires will only be done in very rare occasions. Therefore I can accept the fact it will take 45 minutes to air up 4 tires.
So, the compressor you need is directly related to what you intend to do with it, and how frequently you intend to use it.
-jm
FreeManDan
Things I would rather use in order of accessibility
http://www.walmart.com/ip/Campbell-Hausfeld-12-Volt-Inflator-With-Light/15135633?findingMethod=rr
http://www.walmart.com/ip/Masterflow-12v-High-Volume-Air-Compressor-Inflator/12321236?findingMethod=rr
http://powertank.com/products/sfID1/13
http://www.compareautomechanics.com/wordpress/wp-content/uploads/2010/03/tire_air_pump_at_gas_station.jpg
P.S. I should mention that I have done it before, twice, but me and my brother would trade off when we got tired (no pun intended). It was over a decade ago when me and my brother were teenagers, we shoulda fixed the spare the week before...dumb teenagers
alexrex20
you don't need an ARB compressor to air up tires. in fact, i would advise against it. there are better compressors that are faster, cheaper, and more reliable. i warrantied my ARB CKMA12 three times before i got smart and sold the last replacement. now i use a Viair 450C-IG with a 2.5gal tank and couldn't be happier. it airs up my tires and powers my lockers.
as posted above, just get one of the portable 12v compressors from Wal-Mart or Target or Sam's or wherever. it sounds like you only need a compressor for the off-chance scenario that you need to air up a single tire. if you don't make a habit of airing down your tires, there's no reason to spend big money on a compressor that you'll use maybe once a year.
Splat
I actually ended up buying a
Master Flow Tsunami from Petboys for a very reasonable price (inexpensive!)
Portable, and ideal for what I'll be using it for (occasionally), and like the idea that the it uses battery clamps vs a 12V plug to power it.
Tested it a few days off the generator, and it worked wonderfully (so far)!
Henrybrowne
