XJ Project Short Bus
xjjeepthing
A few pics of my Jeep from stock to now.
The day I picked it up
Budget Lift and 30's
3" and 31"
The day i removed the flares
Trimmed and 32's and bed lined
4.5" of Lift 33's and flat flares
Interior Stuff and underhood.
Still need a rear tire carrier bumper (thinking Detours) and a few more interior things, Build has become more oriented towards weekend camping and fishing.hunting trips
alexfm
Nicw to see you here on ExPo, I've seen you around on a couple of the XJ forums.
Welcome. :D
Im really digging those flat flares too. :drool: They fit perfect with the bedliner.
mudbutt
Still need a rear tire carrier bumper (thinking Detours).....
I have the Detours Tailbone ... You won't be disappointed.... I love mine.
Just know that when you get ready to drop the $$$$, he's very busy. Last I heard he was 3 weeks lead-time on these. You might want to call.... (The demand is very high because of the design/quality of the product).
Spectyr
x2 on that. I ordered mine last August and only got it in November. The product is great though. Give Mark there a call and speak with them directly.
BEVAN
Yup, I ordered mine in early Jan should be here this week.
xjjeepthing
Tell me about the axe setup?
Pretty simple, pulled the rear panel and drilled my holes to line up with the holes I drilled in the axe handle, used some 2" square 1/16" flat steel behind the panel with holes drilled in the center. Pushed the bolts through the panel and plates. Put a nut on the outside the panel to hole the bolt remounted the panle and installed the axe, Found some nice plastic sstyle wing nuts at lowes to hold it in place, Also have a small shovel mounted the same way.
