Artistic Shots- Well thought out, framed (positioned), artistic shots only please.
Tucson T4R
I still need to play more with the strong ND filters. I took this one a bit too far and should have stepped back a notch or two to just frost the water movement but not turn it into total mist. :elkgrin:
Bright sunlight with 10 stop ND filter.
smslavin
A little street shooting from the Big Apple while I was there for my little brother's wedding. After so many years of making it a career, I must say, it was a little hard watching someone else shoot a wedding, especially your brother's.
JamesDowning
Taken at 00:20 hours :sombrero:
ISO400
F11
366 seconds
Pretty incredible, especially knowing the details of the shot.
I'm curious, how do you know the proper exposure time? I assume you took a few different shots to dial it in properly. Or is your camera able to properly pick exposure in low light environments like that?
Also - no wind? I would have expected those flowers in the foreground to be blurry. Really really awesome.
photoman
Thanks everyone- I enjoy shooting at night when possible.
James-
Exposure time can be calculated a couple ways. If you are into the math of exposure, aperture, and ISO the easiest way is to shoot F2.8 at ISO 1600 and get a proper exposure time at those settings. Then you simply adjust your exposure by the same number of stops you adjust your aperture and ISO.
Personally I shoot more by feel than by numbers and can often get pretty dang close by just looking at the scene and doing some brain calculating. For this shot in particular I knew I wanted as much detail as possible (I like shooting F15-F22) but didn't want to wait 30-40 minutes for each shot. I opened the aperture to F11, used ISO 400 because it would allow a good amount of light in without being too noisy, and from looking at the scene (and having shot at night a few times) figured 6 minutes should be pretty close. The moon was 97% on this night with mostly clear skies but we did have some light clouds streaking through. Truth be told I did have to bring this up a little over a stop in post but that was a pretty good first go. :ylsmoke:
As far as the wind, I had been out along several parts of the coast for a few days and I knew that the calmest part of the night is usually between 11:30pm and 2:00am. I also these particular flowers having a good size stem were not being affected by subtle breezes.
Hope that helps.
smslavin
Surf has been way flat but it had been far too long since I had the camera in the water. Couldn't wait any longer.
Now, if I could just find the time to get the truck dirty...
photoman
A couple more night shots.
1.
20:30
ISO 160
F14
30s
2.
21:43
ISO640
F14
10s
3.
05:55
ISO200
F13
30s
4.
22:50
ISO400
F8
245s
smslavin
Surf's flat, desert is melt your face off hot and I'm writing way too many lines of code these days. Went to try something different.
project13support
