onewhippedpuppy
I've had my D1 for a few months now and have fixed the broken stuff, now I need to perform a good baseline to make this a vehicle I trust to drive anywhere.  Basic stats are 1997 Discovery, 105k, mostly daily driver duty with some light to moderate trail use planned.
Stuff that's been done in the last year: plugs, plug wires, thermostat, front wheel bearings, CV joints, lube in the transfer case and diffs, transmission fluid, radiator, water pump, coolant tank, anti-freeze, temp sensor, fan clutch, serpentine belt, and air filter.
Stuff that I'm planning to do: power steering fluid, brake bleed, fuel filter, O2 sensors, coolant hoses, PCV filter, ATF filter.
So, what am I missing?
