Switching from a GS1200 to a KTM 990
zolo
This thread is about the differences and things I liked about the 06GS and also the 08KTM.
The GS was a 06 and well set up. EFI ABS 17” tubeless alloy wheels
The KTM is an 08 and well set up. EFI ABS 21” front 18” rear spoke tube wheels
Both bikes were bought for less than $10k, well set up.
So after putting many miles on my GS also with a ride to AK from ATL I loved the bike. I thought Id never sell it or consider another bike. But the time came to move on.
After farkling out the GS I knew it would sell. It sold within a week and I never even advertised it.
After a month or so of thinking about a new bike. I considered a KTM 990 ADV. But they are hard to find used. I looked for a few weeks. Of coarse I found new ones but they were
$14k plus. That was for a stripped down bike with no bags or any comforts like heated grips.
After awhile I found a used one. At a BMW dealer of all places in NC. It was already set up. bags, heated grips, nice hand guards. I went for it and so for I've loved it.
2006 GS (non adv)
THESE LISTS ARE KINDA THE SHORTR VERSION.
THINGS THAT CAME TO MIND MORE OFTEN THAN OTHERS.
LIKES
very nice long distance comfort. (for an adv bike)
great torque, pulled hard in every gear.
nice cockpit area, bar width, tank length.
adjustable seat from the factory.
great fuel range.
DISLIKES
It was a tank off-road.
the ABS was a little finicky, (never failed but temperamental)
the stock wind screen was awful.(changed to a Deserto 3 TouraTech)
the stock suspension was ok but not great, two up was not the best with gear. It needed some tuning for weight.
2008 KTM 990
LIKES
It is comfortable from a cockpit standpoint, bar width, tank length.
plenty of power.
GREAT off road!
the parts are all very nice, Brembo brakes, WP suspension, body work is very well made.
Nice digital read out and nice tach.
excellent factory hard cases.
DISLIKES
Seat is very stiff, not great after a few hours.
it has no fuel gauge
has a smaller in relation to the GS tank capacity, EDIT this is very slight. The range is less than the GS however.
has a lot of throttle snatch. on/off
The EFI/engine is not as smooth as the GS
So things I considered and should be considered for both bikes. I was under the impression for a long time the KTM would be taller than the GS. I was wrong about that. The KTM is actually the same if not a touch lower than the GS. Now my KTM is not the “S” model so it has a 33.8 seat height. Similar to my non ADV GS.
The ADV GS and “S” model KTM have more like 36” seat height. This is tall, esp. for me off road, I feel like it would be a handful. But the suspension height gained is also a plus off road so it's a trade off.
The KTM is a traditional chain drive, and traditional suspension fork front end.
What this translates in day to day is under heavy braking the KTM has brake dive. Also there is up keep involved with the chain, both keeping it lubed and clean and keeping the tension right.
The plus side is the gearing can be changed easily.
The BMW has a Para-lever front end. Basically two links and a spring shock that links them. This helps with handling and braking. The BMW had virtually no brake dive and you could controllably apply the brakes in a corner if needed. The BMW also has what's called a final drive more similar to a differential in a car. It uses a single sided swing arm and a drive shaft from the trans to the Final Drive. It needs maintenance despite what BMW said initially. Changing the fluid is needed. On the 06 this meant removing the upper bolt and brake then swinging the FD back and draining the fluid from the filler.
Also you would have to disengage the drive shaft at the slip yoke splins. Kind of a fidle
In these years BMW stated “forever fluid” this is not true. I changed my fluid twice while owning it..
All this is probably very rudimentary for most of us here on the Portal, but worth noting as a big difference between the bikes.
I really like the KTM off road. With its dirt bike size wheels and tires it is a great handling bike in the rough stuff. But for the long haul the smoother BMW motor was nice. Don't get me wrong the KTM is smooth but just not on the same level and the opposing twin.
In the twisties how do the two compare?
The BMW was a much more forgiving bike to ride. It was a bit easier to ride hard in the mtns. It could be thrown around and hard braked with some error and still feel solid and not out of control. The KTM requires much more rider control both with the front and rear brake and the throttle. It would not be as forgiving of an error under hard riding. For me this is true
How tall are you?
Im 5'11"
Compare the wind protection?
The wind screen on the KTM is better, a little buffeting but not terrible.
The GS stock screen was bad and needed to be changed.
Weight comparison as pictured?
The KTM feels way lighter loaded and unloaded and rides like a lighter smaller bike, even if it is similar in weight and size it doesnt feel it.
This is my opinion. If anyone would like to add to this list of likes and dislikes plus differences please do. But do not in any way try and grill me or my thoughts on these two bikes. I'm friendly and am writing this in a friendly manner to try and give some insight to these two bikes to our smaller ADV moto group here on EXPO. I've ridden the hell out of the GS and logged some on/off road miles with the KTM since I recently bought it. I think they both rock as travel bikes if you are looking to leave the pavement for some or all of a trip.
Cheers Daniel
LandCruiserPhil
Fair write up:bike_rider:
How tall are you?
zolo
How tall are you?
BAMM I added your questions in.
Yes it is fair, my first time trying to compair two great set ups.
I hope to improve. We will se if I do.
But I still wanted to share my thoughts about the bikes.
Stumpalump
How do you think they would compare on 2 up day trips? Or really how well do you think the KTM would do with two on it?
HMR
Rendezvous Conspiracy
Nice write up.
I did the opposite: I went from a 2005 950ADV to a 2007 1200GS (non ADV).
I'm not worthy of either bike. :bowdown:
WU7X
Snow on the Roof
Thanks for the review.
Very nice writeup. It's refreshing to see an honest appraisal from someone who has more than just a few days/miles on both bikes.
I guess my only question would be; which one would you buy again?
zolo
The GS was nice 2 up. I think the suspension would need to be tweeked if 2 up would be a regular thing. The stock suspension did bottom out a few times over big bumps 2 up. The passenger seat is separate from the front seat so I can see it being more comfortable for the passenger.
The KTM I have not had 2 up. But I will say the suspension seems to be really nice. I had it loaded down on my last multi-day trip and it never once bottomed out, on or off road. The seat however is all one and maybe it might not be as comfortable for the passenger. Maybe someone with 2 up time with the KTM could say one way or the other.
I will know for certain very soon. When my better half arrives.
Thank you. Its my first write up on anything related to my equipment so I think it needs more detail. But thank you.
Id would not hesitate to but either bike again.
The GS has just gotten better over the years and so has the KTM.
I will say this. If I was buying an big ADV bike and I knew I was going to seek out dirt roads and off pavement rides for any duration long trips or day trips Id go for the KTM.
If I was wanting a big ADV bike that I wasn't really seeking out the dirt but I wanted the ability to ride it without issue Id go for the BMW again.
It was ok off road and did awesome up to Prudhoe Bay, but it was top heavy and even on the side stand in the dirt would sometimes fall over. It was a heavy beast and made it harder to really ride hard off road. Maybe a better rider than myself would scream on the GS but I'm 5'11" and 160lbs. After a full day and being tired it was simple heavy, you know?
I hope this helps a little.
zolo
HMR....Your totally worthy man. We all are. We love and respect the bikes and they are a blast to ride. Its what makes us happy. Great photos BTW.
zolo
Over night on the KTM
I decided for another overnight trip. I left ATL GA kinda late in the morning and rode north up to Franklin NC then east on 64 through Highlands and on to Rosman NC. To the junction of 215 and 64. I hung a left and went straight to the Blue Ridge Parkway. (BRP)
Once on top I decided I would try the Black Balsam F.S. RD 816. This is an easy 4wd rd for a truck and a very popular route to get to Shinning rock Wilderness by foot, if you don't want to hike the more Difficult Art Lobe trail. It was muddy and very rocky as usual. I was alone and I had my SPOT. Hooray fro me right.
The KTM did great and a better rider would have had an easier time with the loaded down bike. There were a few rocky spots that proved more difficult than I expected. I rode all the way to the edge of the Wilderness, It was super windy and cold. After some thinking I decided to camp elsewhere and ride out now. If it got super cold and the bike didn't want to start or other bike related issue Id be in a tight spot alone. So I turned around and rode out. I found a good spot in the Pine trees sheltered from the wind. I was worn out and passed out at 630.
When I woke at 730 Am it was 23 out. I had to make myself get up and move around so as not to freeze to death. After loading up and getting out into the sun it wasn't to terrible. still it was below freezing for a while. I rode North on the BRP and decided Id pick up 276 S to Brevard and have breakfast. Then rode 64 west back track to Highlands and then 106 S to Dillard GA. That road was awesome. S on 441 to Clayton, 74 west to N GA and 129 up and over. It was a great ride and turned out to be a very nice day with warmer weather and worth the frozen night to get a full day of no straight roads.
At the end of the day I looked in my side mirror to find a GS following very well as I pushed the corners and tried my hardest to scrap the bags of the KTM. He and I rode hard through N GA and passed a group of Harley's. Sorry guys. I didn't want to be in that parade. Neither did the Phantom GS rider cause he passed with me. We both stopped at a local motorcycle shop and hang out in Dahlonega. Turns out he was a very cool guy and was a true to life Phantom rider. An ex F4 Phantom pilot. Had a good chat with him and ate lunch. All in all the KTM is pretty damn fun.
Next for the bike is new tires. the Scorpions are shot. I have found I need to adjust my riding style from the low revs the GS needed to keeping the KTM in the revs as it rides best that way.
This is half trip report half how things have progressed with the KTM.
zhukoveli
