How's the injection pump? Now would be a good time to put in new seals (the easily accessible ones).
Oh man I can't wait.. I wish I could help
Anybody know of a really high-quality, high-flow fuel sending unit? In order to do the rear shackle flip, the tank needs to get pulled. Since it's such a PITA to pull a tank, I want to replace the sending unit while it's apart as preventative maintenance. $100 now as opposed to hours of labor down the road seems cheap.
What starter is in it? You should replace the starter solenoid contacts in the starter while you can get to it easily. My starter was having a hard time starting, and the solenoid/contacts were shot.
http://www.fostertruck.com/dodge/starter faq.htm
Plus install,
BLUE WIRE (Fusible Link), and thats all you need for the starter.
Check with FASS or Geno's Garage or Quad4x4. I think I've seen various versions around and about. There's the Vulcan fuel tube - as to sending units, stock always seems to work pretty well for me. Still using the stocker in mine.
I am confused, are you asking for a fuel pump or a sending unit? When I hear sending unit I think of something for a gauge.
Mallory makes a unit that has I believe a 3/8" port on it. Summit used to sell a brand that was high end, had a bunch of anodized aluminum parts with high flow ports in the 1/2" size as well. Magnafuel was the brand. They were pricey and I don't remember finding one that went up to the pressure I was looking for
At the time I was designing a knockoff Vegistroke system, I found several pics hidden on his site of the system before he went into full production, he was at first using an Aeromotive unit but it kept burning up, he then went to the Mallory.
Your welcome. I would still open up the solenoid and check the contacts, and also put on the diode for safe messure.Thanks for that link. I haven't visited that website before. It looks like they sell some good products. The starter is in good shape right now, but I might upgrade with some of their parts down the line.
My Suburban has an in-tank fuel sending unit that is the same on both gassers and diesels.
I hear rumors about fass, their quality is going down the drain and instead go with airdog products. Fass was a father son business and when the father retired the son took over and quality took a crap. The father came out of retirement and started airdog and the quality is there.
