Hello fellow outdoorsey internet people!
I am starting this thread to share my simple camper / motorcycle hauler build as it progresses. The goal is to end up with a minimalist rig that I can camp out of and still use to haul stuff without ruining the inside. Progress has been slow so far.
Starting point for me was a 1992 G3500HD with a Quigley 4x4 conversion. High top, swing doors, 20,000 mile cargo van. The van was owned by the state and was used for water line inspection. Interior was walled off right behind the side doors, office area with monitoring/recording equipment up front, camera rig in the back. Camera was like a little tank that would crawl through drain pipes dragging several hundred feet of cable behind it. LOTS of equipment was in this thing; I removed about 2500lbs of it. Anyway, none of that really matters except that it left a ton of holes in the floor, which I have been patching (welding solid) in preparation for rust proofing paint.
I installed a fan-tastic roof vent in place of the large, heavy AC unit that was on top. I dont plan on staying near shore power or installing enough batteries to run such a thing, and a bit of stealth is important to me. I also have two small solar powered vent fans that I will install in place of the two strobe lights on top.
Insulation and sound deadening plan right now is 1/8" ensolite on all walls and doors, then pink foam, then most likely plywood over that.
Floor will be Frost king adhesive foam, then the pink stuff, then plywood, with rubber utility flooring. Tie down tracks for versatility and hauling.
Minimal cabinetry on both sides.
As I got it:
After installing 265/75 r16 BFG All Terrain KO2's, and losing the alternator pulley:
It has already been great as a bike hauler (Buell XB9 and BMW F650 Dakar inside):
Hauled 10 railroad ties home one day as well:
I've been working on some graphic schemes to make it less creepy one day (I work at a facility that can cut vinyl cheap for me):
Also started ideation on the interior layout. I spent a good bit of time creating a spot-on template for the profile of the interior sides of the van, before trying it at several places along the sides and realizing the van sides are not consistent all the way down. This is a bummer as I hoped to cut everything out with a cnc router. Guess I'll have to go old school on some of it:
The name is still up for debate as well. I love this thing
As I got it:
