2002 Nissan Pathfinder w/ Old Man Emu suspension
That's normal. The struts are now pre-extended by the amount of your lift, and when going over large bumps, they don't have as much down-travel as they used to to absorb the bumps, so they are topping out. Totally normal. After about 85,000 miles, mine still does it. It's not gonna go away, or cause any problems, just something you'll get used to and you can even use it to scare the bejeezus out of passengers! :wings:
Ya that is normal, it can get annoying, but you just have to drive over speed bumps a little slower or air your tires down when you go off road. And it is freakin funny when you have a passenger in the car and it clunks, I usually play along like my tire is going to fall off or something like that. :punk03:
With that tire size you should still get good MPG.
Thanks for the info. As I said, I couldn't see anything loose at all, so I figured it was just one of those quirks. So far, the MPG has stayed the same. My wife was concerned it would reduce it. I couldn't imagine it affecting much with 2" of lift. Anyway, very happy with it. I am also happy I went with heavy all around instead of medium rear. Simply the amount of stuff I keep back there with 2 kiddies requires the extra spring rate the heavies provide.
I will get those shock pics right away...
Which coils did you go with up front? Light or Heavy? Looks like you got a little more than 1.75" out of it! Has it settled much yet?
I went heavy all around. I do think I ended up with more that the listed amount of lift, but that may be due to the fact that it had sagged out quite considerably.....
You will only notice a change in gas millage if you get bigger tires.
This might be negated by the narrower tire.
So....Mr. Moody, hate to bug ya, but have you had a chance to snap those pictures of the shock mounts?:shakin:
So sorry! I spaced it, but I sure will...
Okay, I am a lollygagger, but here they are. I don't have your email anymore, so I'll post them here, but I have a few more I can email to you if you'd like:
Thanks! Just what I needed. Mine are different. Farther back on the "frame" and they are studs. The nuts are seized up and I need new shocks, and was looking at the 99.5"+ upgrade anyways. Thanks again man.
OME looks great!
I test drove a Pathy before I bought the Trooper and really liked it - if I would have found the right one at the right price - I would have bought one...'course, if I would have known at the time what the OME lift would have looked like, it would have been really tough not to go with one...:truck:
bootzilla said:
OME looks great!
The Trooper OME Kits look great as well. A friend has it on his Trooper, and it turned out quite well, along with his sliders and slightly larger tire...
ELShockley
