This is a very cool build and from what I can tell very close to what I'm building. I'm building a 70 K10 sitting on a 2002 2wd frame with a 2003 6.0 4l80e. I'm going with a double triangulated 4 link front and relocated 63 inch spring in the rear. Hope you don't mind me asking you a few questions, here's my junk.
Right on, I really appreciate it. Wow, so where to start....
1. It appears that your using a 2wd frame and since I see no sleeves for a steering box that this truck also had rack and pinion? I read you plan to move your axle 4 inches forward and it appears you planning on Hydro assist from the pics, how do you plan to handle the steering box? I'm considering a mid 80's forward swing Ford F150 box to allow room for the stretch. Basically I'm going to move the steering box forward 1" and plate the inside of the frame. I was fine with the stock box with the axle moved forward 3 inches so moving the box 1" should be fine.
2. Any chance you know your current frame and axle side hole to hole numbers for your link mounts? I'm hoping to achieve at a minimum of 6 at the frame and 9 at the axle.I don't remember them offhand but I can measure one evening for you.
3. I'm looking forward to the coilover setup, I'll be interested in how much lift you plan to run and what spring rates you end up on.I'm shooting for the same lift height I have now, 5 inches +1 inch bodylift. which on 40s should be a really ecent compromise between belly height and low CG. I cannot remember what springs rates I ended up with but I'm sure I will end up changing them at least once to get where I want to be. I used FOAs app on my phone to calculate the rates.
I'm sure I'll have a thousand other questions and I appreciate you taking the time to answer these.
Jerry
Thanks for the information, any input going in will save me tons of time. I noticed you have the same frame side engine mounts as I do. They hang about an inch or so below the frame rails. To keep them from interfering with my upper I was planning to run my upper on the outside of the frame rails. I also considered cutting them higher, is your current setup outside the rails? From the pics it looks like your lower is mounted on your crossmember.
