2012 Tundra Limited Overland Build. **Price update**
IndianCreek1976
2012 Toyota Tundra Limited CrewMax 4×4 — 5.7 L V8 | 275,0xx miles | Greenville, SC
$25,000 – clean SC title in hand
I believe this is a safe space to say that today is bittersweet, as I am offering up a member of the family that has been central to more life memories and amazing adventures than most people would understand. She has been so much a part of my life, I have been working my way up to this moment since we left Colorado 3 years ago.
Second owner for the past ~220 k miles. I’ve logged every upgrade and major service (≈ $30k total) in a shareable Google sheet with receipts filed and available. The truck is truly turn-key for daily duty and extended overland travel. The high mileage is due to a 3 year commute I did from Islamorada, FL (MM88) to Dadeland, FL. (150 miles round trip). She easily navigated florida flats fishing duties the first half of ownership, and gradually converted to over landing after we moved to Golden, CO. in 2016. If you like wild wide open spaces and exceptional music quality at high decibels, take a look. If you just want a ************ truck with an amazing sound system, probably take a look too. No expense was spared, OEM replacement parts were always used when their use impacted durability. Top rated service providers and non-OEM parts were always selected, typically the #1 provider I could find. This meant waiting lists and all that, but I only wanted the best work done to preserve and extend the reliability I have always gotten from this truck. She was strictly an over landing vehicle, I wasn't into rock climbing or mud. Just far away places.... You can confirm this by visual inspection of the undercarriage.
If you're interested in my professional background, if that helps reinforce the attention to detail and integrity that went into the truck: US Navy vet, with a dab of OCD.
LinkedIn: https://www.linkedin.com/in/masonwj...re_via&utm_content=profile&utm_medium=ios_app
Condition - Overall Excellent for Mileage​
  • Exterior — Grey Metallic paint still shines; ceramic coating, decal blackouts and headlight updates with tint on all windows (sides + front), there are door dings and minor chips (rate 8/10).
  • Interior — Limited-trim leather (seat heaters, power moon-roof, dual-zone climate) shows mild bolster wear but no tears or odors. All seats excellent shape, driver is only one that shows wear. Husky liners front & rear since day one, carpet good to go. (rate 8/10)
  • Mechanical — Complete check-up with full mechanical green light. Everything serviceable up to date, tires and brakes up to date. (summary below, rate 10/10).
Major Upgrades & Equipment​
CategoryHighlightsInstalled @ (mi)Cost*
Suspension, Steering & HandlingOld Man Emu expedition kit: OME-612 coils, Nitrocharger Sport shocks, SPC adj. UCAs, diff-drop, Dakar HD leafs, sway-bar bushings, new OEM LCAs & cam hardware, Hellwig rear sway bar
Complete front end re-build with OEM parts at time of suspension mods. (control arms, bushings, cam sleeve/bolts - She rides better than new on or off road)
252 k$6,042
Wheels & TiresKMC Mesa 20×9 wheels + Nitto Ridge Grappler LT285/60R20 A/Ts (installed 270 k; 5 k mi on 55 k warranty)270 k$2,399
Armor / UtilitySnugTop Rebel topper w/ integrated 40″ LED bar • Rhino-Rack Pioneer platforms (cab + topper) • Decked drawer system • Leer Locker overhead shelf213 k$3,348
LightingMorimoto / TRS XB OEM-grade LED headlights245 k$1,033
Audio & ElectronicsSony XAV-8050D 8.95″ CarPlay/Android Auto head unit
JL Audio C7-350 mids, C5-650 mids & tweets, dual PowerWedge 12″ TW3 subs, Memphis Audio 1K Watt Mono for Subs (I installed the second sub and the memphis amp)
JL VXi 800/8 DSP amp, full active re-wire & tune (Elevated Audio - component audio + amp and tune)
• All interior / cargo / reverse lamps converted to LED
240–246 k$6,948
Maintenance (recent)See table below – full fluids, brakes, rear-axle bearing, etc.$4,735
*Parts + labor, per build sheet.
Google Sheet - Notable Upgrades & Maintenance:
Recent Maintenance Highlights​
DateOdo (mi)Work Done
18 June 2025276,017All fluid service (including transmission and filter, brakes, coolant, AC charge, XFer Case, Rear Differential etc), Replace coolant value plate and inlet pipe o-ring, resurface front and rear rotors ($3,549)
(Took truck in for full service and requested they check everything to ensure everything mechanical in working order, resulted in above work)
05 May 2024~270 kNew Nitto tires, balance, 4-wheel alignment (print-out available)
25 Jun 2022~250 kAll fluid service complete brake bleed, P/S fluid, diff & transfer-case service etc + new rotors and brake pads
19 Aug 2022~252 kOME suspension install + full front-end rebuild (see above)
14 Jan 2021~235 kRear right axle bearing + full driveline fluid service
Oil changesFull-synthetic every 10K
Google-sheet with line-item costs, dates, and PDFs of every invoice is ready to share.
Asking Price: $25,000
Payment by certified bank check or verified wire at my credit union. Happy to FaceTime a walk-around and to help coordinate shipping where it makes sense. I will personally deliver the truck to any buyer that lives in Colorado, Utah or Wyoming, as long as you don't mind the miles from me driving her west one last time.
DM here or text - 757.589.9295
Please advise on whether this is in a fair range asking price.
EP frowns on us commenting on for sale prices, but since you asked, and you seem like a stand up guy, I’ll give you my impression as if I was in the market, which I was for 2nd gen Tundra back when I bought my ’21 new ‘cause I just couldn’t find any good used deals here that fit my needs.
Your truck prices out on KBB at $10,xxx to 12,xxxx for a Limited Crewcab with [edit typo]27,000 275,000 mileage in Very Good condition. Of your build costs, all but the Suspension and Wheels/Tires are personal preference items I personally would not have paid for or maintenance, which is just expected to have been done. So, of those $8400 in build costs, I would have been willing to offer 50% of that cost since they were pretty new. So, $12K for the truck, and $4K for mods. I would have expected to see it priced around $20K and we might have negotiated or if I could have seen it in person and was really impressed, I might have thought that fair.
Given the the fact that you are brand new to the forum, there’s no real way to check you/your build out via posts and even for a 2nd gen Tundra 275,000 miles is a lot (yeah, I know about the million mile ones), IMO you are likely asking too much. It looks like a nicely cared for rig and I don’t doubt anything you have said about it, but if you look around, there are tons of used rigs for sale. I think things have changed a lot from 4-5 yrs ago when I couldn’t find a decent used Tundra build and plenty of rigs sold super quickly.
Others may feel different. But look around the site a bit more for comparisons. There’s several Tundra rigs with different pros and cons, but all compelling in some way. Just my honest opinion, and again, you did ask.
GLWS
Beautiful truck. My favorite color. I had a 2012 Platinum Crewmax and IMO it is the best year of the best truck I've ever owned.
Can't comment on price but I can say this. I've tried and tried to find a clean, unmolested 2012 Crewmax for years now and it's damn near impossible.
@dstefan's analysis above is technically true but for someone who shops sellers, as I do, your attention to detail down to the ad itself are priceless.
Unfortunately my stable is currently full.
Good luck.
Thanks for taking some time to give me your input fella's. Sounds like a fair adjustment would be moving to a $25K asking price. It's never enough :) but I do want to be reasonable with my expectations on the value of truck.
Going to give this a few more weeks then grudgingly switch to the "used car platforms." It shouldn't matter, but I would MUCH RATHER have someone buy the truck to use it for similar experiences...
GLWS
Thank you for this, Im new here as well and looking to sell my rig. Good advice!👍
5mouse
