2015 Jeep JK Rubicon Unlimited
2015 Jeep Rubicon Wrangler Unlimited 4x4
Factory ordered with nearly every option available with the exception of leather seats. Currently has just over 19k miles on the clock with oil (Mobil 1 full synthetic) and filter changes religiously at 7,500mi and 15,000mi and a five tire rotation (spare included) completed every 5k miles. Willing to assist with shipping via private carrier, arrange pick up at nearby SeaTac International Airport or Portland International Airport, or open to discuss personally driving the vehicle to its new home.
The Jeep needs nothing more to be ready for any adventure you have in mind. In its current configuration it seats 3, due to the Adventure Trailers Stage 2 cargo box and water tank. However, the sale comes with the still new removeable 4th seat (w/ Trek Armor cover) that easily bolts into the factory location.
Please read all extras the Jeep comes with that either have been installed or come with the sale. The photos represent various build stages of the Jeep, but don’t necessarily show all modifications. The modification list is current and accurate. Also note, two items need to be addressed on the Jeep. The windshield will need to be replaced due to a crack, and ¼ of the Rigid LED light bar is not functioning properly. Title is clear and in hand. On to the exhaustive list of parts, extras, and fine details…
Exterior Color: Copper Brown Pearl Coat
Interior Color: Black
ENGINE
- 3.6 liter V6 24-Valve VVT
- Fumoto Engine Oil Drain Valve
- Mobil 1 full synthetic motor oil changed every 7,500 miles
- Genesis Offroad Dual Battery Kit - Version 2.0 software green touch screen monitor installed in cabin within reach and view of driver
- Dual Odyssey Batteries
- M.O.R.E. underhood ARB Compressor Mount
- ARB Twin Compressor
- AEV Procal computer programmer
TRANSMISSION
- 6-Speed Manual Transmission
TRANSFER CASE
- 4:1 Rock-Trac 4WD
AXLES
- Heavy Duty Dana 44 front axle - Disc brakes, Tru-Lok differential
- AEV High Steer Kit
- Heavy Duty Dana 44 rear axle - Disc brakes, Tru-Lok differential
SUSPENSION
- AEV Dualsport RS Suspension - 4.5" lift with upgraded Bilstein 5160 Bypass shocks, AEV geometry correction brackets, Procal
- Airlift 1000 Helper Spring Air Bags, rear coils only, plumbed independent of eachother
WHEELS and TIRES
- Hutchinson Rock Monster Double Beadlock Wheels (5) - Powdercoated flat black
- Gorilla Locking Lug Nuts (all lugs including spare wheel) - black, comes with key
- BFG All Terrain T/A K02 Tires 37x12.5R17 (5) - All tires rotated every 5k miles for even wear, to include the spare, approx 12k miles on the complete set, no rips, tears, plugs, repairs or damage of any kind.
TOPS
- Factory Mopar Softop, black sailcloth w/ dark tinted windows, door surrounds, etc, never installed
- Bestop Trek NX fastback soft top
- Factory Hardtop, windows tinted to 15%, rear wiper and washer
- Adventure Trailers aluminum propane tank mount and corner bracket powdercoated flat black
- Manchester 5lb propane cylinder
- Rhino Rack JK Backbone Roof Rack w/ newer low profile 1” metal mounting feet and interior bar padding
- Rhino Rack Pioneer Platform
- Rhino Rack Foxwing awning mounts (can be used with other awnings)
- Rhino Rack 50” load roller mounted to rear
- Rhino Rack full width cross bars for RTT or other accessory mounting
- James Baroud Space Evolution RTT (spidering on top shell, integrity and weatherproofness not affected). Comes with aluminum ladder and 3” foam mattress.
OPTIONS as ORDERED
- Remote Keyless Entry (2 Keys)
- Security Alarm
- Dual Top Group - Premium black Sunrider soft top (tinted windows), Freedom Top 3 piece hardtop (tinted windows), Rear window wiper/defroster/washer
- Connectivity Group - Electronic Vehicle Information Display, TPMS Display
- Max Tow Package - Class II receiver hitch, Trailer tow with 4 pin connector wiring
- Air Conditioning - Auto temp control (thermostat), Humidity sensor, Air filtering
- Heated Front Seats
- 115 Volt Aux Power Outlet
- Tinted Windows (15%)
- Engine Block Heater
- Alpine 9 Speaker Audio Group - All weather subwoofer
- Uconnect 730N CD/DVD/MP3/HDD/NAV - 40GB hard drive, SirusXM Travel Link, SirusXM Traffic, SirusXM Satellite Radio, Remote USB port
COMMUNICATIONS
- Yaesu dual band FM HAM radio FT-7900 w/ detachable remote mounted faceplate, Uniden 7 watt external speaker mounted in sound bar. The radio is mounted out of sight and wires run discretely.
- Comet SBB5 dual band antenna
- Diamond HAM Antenna Mount - No drill
- Magnetic mount for HAM radio mic
- Pana-Pacific External SirusXM Sat. Radio Mount
ARMOR
- AEV Premium Front Bumper, AEV winch mount, AEV front skid plate, all brand new
- Warn 9.5ti Winch - Just serviced with brand new factory bushings, thrust washers, gaskets, seals, grease, and powdercoated flat black
- Masterpull HD Superline Synthetic Winch Line (3/8 X 100') with rock guard and heat guard, brand new
- Rokmen Big Hawes Aluminum Fiarlead, brand new
- Drake Offroad Mesh Grill Insert, black
- Offroad Elements Stealth Limb Risers
- AEV Rear Tire Carrier w/ 10 Gallon Fuel Caddy (siphon hose included), AEV Hilift/Pullpal Mount
- Mopar factory fuel door, black
- N-Fab Nerf Bars w/ Steps
LIGHTING
- IPF Driving Lights, brand new not yet mounted
- Crawler Conceptz 50" Light Bar Mounts - Painted to match JK
- Rigid 50" E-Seires Double Row LED Light Bar
- Carolina Metal Masters LED Light Bar Locks w/ Key
ADDITIONS
- Vector Offroad dash bar, full width
- RAM Mount rear view mirror mount
- Masterpull grab handles (set of 4)
- Weather Tech floor mats, full set
- Custom 4 switch panel w/ ORWTTA illuminated switches
- Blue Sea 12 port fuse panel mounted behind trim piece under dash
- Nakatanenga 4x4 rear window vents
- Weather Tech rain guards/wind deflectors, set of 4
- Trek Armor seat covers, set of 4
- Trek Armor center console cover
- Springtale Solutions headrest mounts for backpacks or bags, set of 2
- Raingler Nets interior roof net
- Adventure Trailers Stage 1 and 2 lockable cargo drawer system w/ 6’ sleeping platform extension, 13 gallon water bladder, whale water pump, 6 liter European water heater, finished in LineX and topped with anti-skid protection matting
- Adventure Trailers interior cargo rack
- Eezi Awn medium aluminum camp table, mounted under A/T rack
- Outback Adventures tailgate table w/ bamboo cutting board
- Adventure Trailers fridge/stove combo slide w/ Partner Steel double burner stove and propane hose
- National Luna Weekender split stainless steel fridge/freezer unit with vehicle battery monitor
- Magnaflow high clearance full exhaust system coated in hi temp flat black paint
- 3M window tint 15% all windows
Also up on eBay....
http://www.ebay.com/itm/222458730559?forcerRptr=true&item=222458730559&viewitem=
This JK has well over $20k worth of aftermarket extras and is ready to go on any adventure you may have in mind. Listed on EBay and other sites currently for "buy it now at $63500," but I'll gladly entertain offers and partial trades for something interesting from expo members. Keep in mind the photos show various stages of the build, but the above list is how the jeep currently sits.
Paid in the mid 40's for the Jeep and well over $20k worth of extras not including labor. Open to offers on the Jeep and will entertain parting it out as well.
ELShockley
