RAM5500 CAMPERTHING
OG Portal Member #183
Listen to your friends. Those hinges are horrible.
Care to elaborate?
Just agreeing with them on the hinges. The latches are very nice though.Care to elaborate?
I feel you have these cool recessed latches that look like current generation hardware. Then you are using these 1930's hinges that just don't fit the quality of the rest of the build and they are an eye sore.
I do understand simplicity but I would think there would be a better hinge out there that is still simple and more appropriate to match the quality of everything else you have done.
I used piano hinged on a set of aluminum cabinets I have built. The frame was 80-20 radiuses profiles. You could use piano hinges if you simply add a small aluminum angle to the backside of your plywood fronts. Could even add-glue a strip of wood to back side. Both methods will provide a way to secure the hinge.
We found that with conventional overhead cupboards, stuff wandered up and down, so we put everything in boxes.
Cheers,
Peter
OKA196 motorhome
CamperthAng,
I checked out that microwave. These are the first six advertised cooking programs:
HotPockets would be "dinner plate", I'm thinking? Hah hah !
- Popcorn
- Potato
- Pizza
- Beverage
- Dinner Plate
- Frozen Vegetable
Loving this build. Did you see that Total Composites is about to introduce semi mass produced truck campers, purportedly weighing in at around 1000 pounds?
Nice work so far.
Don't sweat the comments on the hinges - I feel like most folks are missing the point of the 80/20-based construction by suggesting hinges that would require you to make permanent fastenings into the extrusion instead of keeping everything modular and removable.
EDIT: Hit post too soon and forgot to post this:
https://ourkaravan.com/attaching-cabinet-hardware-to-8020/ - a method for attaching euro-style hidden face-frame hinges to 80/20
Ha, $100 will be about 25 cases of the US's traditional breweries (or at least it should). Now if you are into craft beer then you are talking about 4 to 6 cases.Yeah, that guy does amazing work and ive followed him awhile.
But for those hinges he used.... Talk about making something VERY simple, as complicated as humanly possibly!
Also all those bits and pieces he used add up to close to $100 PER cabinet. Thats a lot of cheap beer
