Thoughts on your Sterling 60 amp B to B charger at this point? I see they are making a 120 amp, would you consider something this big?
Absolutely love it and it works exactly as advertised and confirmed with the Victron app that its putting out a true 60 amps to my camper.
I'd absolutely consider the 120 version, and might actually still go with one if i end up adding a second battery.
Only reason i didnt get the 120 at first was the size, but turns out i have plenty of room.
Double check the dimensions of them before ordering, they are pretty damn big, and take up some real estate, but 100% worth it in my opinion.
Luckily that @danneskjold fella has a fetis for used crucial electronics, so if i move up to the 120, i already have a buyer for the 60! hahaha
Hey man, my Airhead isn't installed yet and I haven't decided on how I wanted to plumb the fan. Stoked that you are liking it as I'm new to these as well and was a bit concerned. It'll be a godsend to have a decent toilet that isn't a nightmare to deal with...and can be used for a couple weeks without emptying it.
1- Where did you plumb your fan for the Airhead? Out the ceiling or to the side? I'm considering dumping that air into the bed of the truck out the side...or out the back, but that is where we enter the camper.
2- How did you mount it to the floor? My camper is all composite as well, not wanting to just bolt it to the floor.
3- Do you recommend using the coffee filters/liners before dropping a boozy deuce?
4- Are you emptying it after the weekend or just leaving it in there as it dries out?
With these big Lifeblues being able to accept the HP, I'm thinking why not, thanks for confirming.
How about two 60s in parallel?
Airhead and the others are not actually "composting" toilets, that's more of a marketing lie, like "solar generator".
The actual composting only takes place after the materials are emptied, if you have an appropriate location for a maintained compost heap.
A better term is "desiccating toilet", and the primary reason they work so well without unpleasant odors is the fact that the faeces are not being mixed with urine.
The coir, sawdust kitty litter or whatever the medium draws out the liquid from the faeces
the mixing atomizes it into smaller particles, accelerates that drying.
And in fact many users of homemade versions have no special apparatus for mixing
and also no ventilation to the outside, instead just sealing up the bucket.
As also with the ammo-can units used in strictly enforced "leave nothing behind" fragile ecosystems.
Back to the Airheads etc style, used properly there really is no unpleasant odour, even when you are very close to the unit
if running the venting out sideways or through the floor is easier then up top, just do what's easiest.
Great summary!
Allow me to add a little bit based on our experience with a Nature’s Head - we used ours for the first year or two, mostly weekends and three or four extended (3-6 weeks) a year without using the fan. When we moved to our van full time, we connected the fan and vented it outside.
Power venting made a huge difference in usability!
No difference for #1 of course but we could manage 4 weeks with occasional use before venting and now can EASILY extend our #2 bin to 4-6 weeks with venting turned on.
I will likely reduce the number of hours the toilet is running the vent once I have all the automation tuned in to reduce noise and power consumption (quite minimal for either).
Great summary!
@RAM5500 CAMPERTHING I checked out your video where you showed the toilet (EP12). Looks like it mounted nicely. What did you use for a vent cowl up top? When you mounted the hose/fan, did you just cut a hole in the panel, drill some holes, throw down sealant and screw it all together and seal?
@WanderingBison Did you vent out the side or up top? I really don't want to run the hose vertically as it looks junky...but I sure as heck don't want to smell my toilet. My toilet is near the entry way on the back and on the side of my awning lol. I could potentially vent it out into the truck wheel-well area (I have a slide-in camper). I could likely turn off the fan easily enough if I just wire in a switch too. I dunno...its awesome that these things work so damn well and for so long. Crazy. I have two adults and two kids using it, hoping it holds up. Oh, do you use coffee filters with yours? Wondering how to best clean it when messy.
The method for the hole though was kind of involved and I was in the zone and forgot to document it.
I found some PVC pipe that was almost the exact diameter of the airhead vent fan cowl piece, drilled a hole just big enough for the pipe to slide through in the roof, then coated the hole, pipe, Inside and outside with adhesive and let it set and seal.
This way, there is no air gap where the stank could possibly permeate Into the foam insulation exposed from the hole. Make sense?
I just used a round vent from a boat.
It’s nice and super low profile.
Here’s a link: JR Products 02-29125 Mushroom... Amazon product ASIN B074JFP3PP
