depark
Hi everyone,
I’m hoping to get some opinions on whether to run 35’s or 37’s with a 5.4. The main question I have is does the 5.4 have enough power to run 37’s with 4.88 gears and still be able to tell up to 6000 lbs.? Just for reference I calculated the difference in rpm for the stock, 4.56 and 4.88 values. All of these are at 65 mph without O/D.
3.73 – 2771 rpm – 29.4” tires
4.56 – 2837 rpm – 35.1” tires – 1.5 mph lower speed reading
4.88 – 2881 rpm – 37.0” tires – 2.5 mph lower speed reading
The way I interpret the numbers is that it can run 37’s and still tow well because of the slightly higher rpm. My reasoning may be flawed, any advice would be appreciated. I do understand that 35’s and the 5.4 are well matched and many have chosen that option. Still are 37’s a possibility?
Thanks
Darryl
Thanks
Darryl
