I seen one truck (a Tundra with an ARB Sahara bar) that has added shackles to the front of the ARB bumper. My only dislike with the ARB for my 2009 Tacoma is that there are no shackles. Where are you guys attaching the winch hook if using a snatch block to double back to the rig? What about if you need to attach a snatch strap?
For those of you that have added shackles, did you add a piece of plate behind the bumper to reinforce the bolts and disperse the stress when hooked up to the shackle? How are the shackle attachments holding up after repeated uses? The factory recovery point on the front is still in place but it is located quite low on the truck, and could very well be inaccessible in the truck was stuck.
