Aeon Rubber
Installed new Fuso OE shocks before going on a road trip this past weekend. Near as I can tell, the existing shocks were original with 195k miles on them. Couldn't tell the difference between the old and the new when compressing them by hand. But there was a huge improvement on the road. They improved the ride just about as much as installing the Timbrens.
Time to bring this thread back to life...
I recently got a set of the front and rear Timbrens for my '04 FG649. The rears got installed pretty easily, but as you can see below, they don't quite line up with the center of the axle. Is this a big deal?
I should note that the rear end is sagging a decent amount at this point, which I assume is what's causing the top of the axle to not be parallel to the frame -- notice how the U-bolts aren't on quite the same line as the Timbrens). I'm getting the rear leaf springs dealt with soon, and hoping that once the truck is leveled out, this will be corrected, the result being that the Timbrens will then hit closer to the center of the axle. Sound plausible?
On the fronts, the OEM bump stop is on the frame side of these older FGs, so that gets permanently removed, and the Timbrens get mounted on the leaf spring side, underneath the u-bolts. As a result, the frame itself becomes the new landing pad for the Timbrens, whereas newer FGs have an actual landing pad up there (since the OEM bump stop is on the leaf spring side). So to those who have installed these on '04 and older models, are there no issues with using where the old bump stop was as the landing pad? I wouldn't think so, as the forces shouldn't be any different from before, but this is the only possible wrinkle I can see with using these Timbrens on the older FGs, so figured I'd make sure.
Timbren's support email hasn't been overly helpful. After approaching them with the above issues, they've told me that there is no application for my '04, and I should return them. I know there are several people on here who have gotten these springs working on trucks even older than mine though.
Timbren's support email hasn't been too helpful, btw. After approaching them with the above issues, they've basically told me that there is no application for my '04, and I should return them. I know there are several people on here who have gotten these springs working on trucks even older than mine though.
Obviously, the leaf springs are a crucial part of a truck's dynamics. Prior to installing the Timbrens did you notice the factory bump stop was off as well? If this is the case getting your leaf spring issue fixed should solve your issue and our Timbren setup should land pretty darn close to center! But in the meantime you shouldn't have any issues with it not being perfect on your frame.
Good to know, thanks. There were no rear bump stops on the truck when I bought it -- the previous owner had had much of the truck taken apart at some point to have the frame sand-blasted and repainted, and the bump stops never got reinstalled apparently.
Wolfbox
