hobietony
Maybe I missed it somewhere, but what are you using to power your A/C?
Nothing yet. It is a standard 120v motorhome AC, so when I get the power hooked up, there you go
ht.....why is important to keep the duallies? Seems most folks try to get rid of them as they pick up rocks etc. If you watch the TV show 'most dangerous roads' they were always fighting w/ rocks between the tires.....????255/85/r16, tallest I can get without spacing the rears. They look too small, but it was important to me to keep the dualies. The 4x4 swap already needs a rear spacer to swap to the 8x170 4x4 bolt pattern, so no way to space the dualies themselves. I am using stock ford alloy wheels, powdercoated.
Sorry missed any conversations about it but then again I am known for short term problems ;>). I agree they do look bad ***, but I would think airing down w/ them would cause problems (such as tires rubbing). As to track with any axle you could put under there you could match or exceed track with the axle/diff you chose (i.e. as you know, check out UJoints thread). The series ' Worlds Most Dangerous Roads' involved several professional truck drivers navigating the worlds known most dangerous roads in large trucks and several episodes they had to cope w/ rocks stuck between the duals. I'm not trying to be a prick but I do hope to build an ambo in the next couple years and the dual thing interests me in what I will do (they do look awesome). You are one of the foremost build threads on the subject so I was questioning as to why you chose what you did.^^^ I've answered this a couple times in this thread, but track width is a big factor, along with weight capacity, and redundancy/safety for blowouts. I've never had a problem with this rig off road as far as rocks, and I think they look bad ***. I don't watch TV, so I don't know anything about any 'Most Dangerous Roads'
bD
