Martinjmpr
Wiffleball Batter
Just thought I'd ask. Seems like it shouldn't be that difficult. Since one of the hassles (at least for me) is fitting the cooler into the vehicle, I've been thinking about making my own.
From what I've seen in the (many!) cheap plastic coolers I've owned over the years, their biggest failing is that they insulating material is too thin, which means it doesn't stay cool for as long as it could otherwise.
I figure all you really need is a waterproof inner container, and then build a box around it with some insulating material in between. the advantage is that you could make it whatever size you wanted and could integrate it so it would fit perfectly into your vehicle without being too tall, too wide, etc. You could also increase the thickness of the insulation so that you'd have a cooler that kept things cooler longer without having to invest in a Yeti that costs as much as a fridge!
For the waterproof inside, you could use something like an Action Packer or even some of those plastic totes they sell at various stores, and then build the exterior box around it. Insulating material could be styrofoam or almost anything else - foam rubber, spray foam (Great Stuff! type material) etc. You could plumb in a drain pretty easily, put heavy duty hinges (vs those stupid plastic hinges that seem to break at the worst time) and so on.
If you were really fancy, you could incorporate it into a drawer so that it wouldn't take up space in your vehicle, just pull the drawer out and your cold stuff is in there!
So I figure somebody out there has probably done this already! Let's see 'em! :ylsmoke:
