Aspen X Trails Kelly Tear Drop build
Pictures of front skid plate installed, the beginning of the plumbing, location of sink and drain, water inlet, shower location, wiring control center temporary install, routing of wires. Hope to finish routing the wires in the morning and llocate propex heater tomorrow, pick up rear skid plate. Temporary install of rear decking, build battery box, drill holes for decking. Holding tank will be ordered in the AM.
Bob
www.aspenXtrails.com
951 692 0958
Bob your quick progress on trailer builds always amaze me, can't wait to hear what new things you have coming! :sombrero:
This one is actually going slower than I had planned. Changing the water tank, adding the propex and the larger holding tank have been a challenge. The skid plates were new also, plus the sandblasting and powder coating has been a nightmare. Doing three colors on the frame was a challenge. I have a due date of mid May, and I am concerned about it. I want to bring it to Expo, but may not make it. When you build at your own pace, it makes things easier it seems. Being under the gun, takes some of the fun out for sure.
In fairness to the powder coating, they had to build a new wrack for the trailer, and with it, only left two inches on each side of the oven. So I can not really say much about their effort, the sand blaster, that is a different story. Enough complaining, back to work.
Bob
951 692 0958
The following are of the Propex heater being installed, the ducting routing, and some of the wiring box. The two small black circles are the heater ducts, the one on the right is heat, the other cold air intake. Wires hanging are for fan, 12 volt hot wire, exterior driver side lights and interior lights.
Bob
951 692 0958
If you ever have any of these that you just don't want and feel like it needs a good home, let me know.... :drool:
As always, looks great
Thanks Thom, one good thing for this one is, that I bought two of the big batteries when planning for this one. So I have one to put in my trailer. I am not sure I am going to be able to buy them anymore. The company was sold, and the new owner only wants to sell batteries by units of 12. I can possibly do 12 105's but 12 255's is just not going to happen. Hoping to have a price for you on Monday. I will look into buying the 105's and make group sale if I can get them reasonable.
Bob
951 692 0958
Do what you can. If it doesn't work no worries. You've already gone above and beyond. I appreciate the effort.
Yeah, 12 of those big suckers would be tough. It'd take you 3-4 years to put them all in trailers.
Got a lot of the wiring done today. Wired in the roof fan, and AC wired, micro wave plug wired. Each 110 unit has a color coded wrap. All have loom guides and bolted to the frame.
Solar Controller is wired other than the connection to the battery. The load side of the controller goes to the 110 controller, that fuses all 12 possible accessories. The 110 is connected to the 110 box, and it charges the battery, converts 110 to 12 volt use and monitors the battery even in storage. 110 line is in and wired to box, 12 solar is in and wired to controller.
Bob
The following pictures are of the passenger side wall cut outs. Hehr door fitting, the front counter, which underneath it will be where the solar panel will be stored. This counter can be used to eat off, but its main function is to carry the action packers, while overlanding. I am doing the walls different on this trailer. I have a trough along the bottom of the wall area for silicone, the walls will be dropped into the silicon, forming a tight seal. These are at floor level. I will also attempt to carpet the walls prior to screwing the sides on. This will make the build much quicker I think. I will cut the carpet up 3/4 inch from the bottom, so it will not interfere with the silicone seal area. I have done this with the galley area with white vinyl, and it worked perfectly. Hoping this is worth while effort. It does require cutting the walls, screwing the walls to the trailer and then removing them. Applying glue and carpet, allowing to dry and then reattachment.
I am waiting on the holding tank that may arrive tomorrow to finish the galley. No bare plywood is visible when the trailer is done, other than the sander ply for the back wall.
Back to work.
Bob
951 692 0958
The following are of the driver side. As most know I am not a big fan of the fancy wood interiors. Just feel they will get scratched all up, as when I am out on the trail it is about the trail, and not being super careful to no scratch anything. Mine are designed to get beat around if need be. I know I am guilty of just throwing stuff in the trailer and heading out. That is the reason for the carpet on mine, and the added sound proofing. I have come up with another way of doing it. It takes me hours to do it the way I have been, so on this one, it will be placed on the plywood with
3M 90 spray on adhesive. Then attached to the trailer. I will pre drill all the holes, penetrate the carpet and then attaché the whole wall. I have made a trough on the sides of the trailer that will be filled with silicone, the wall with the carpet cut from the bottom inch will be dropped into the trough and attached by screws. Silicone will seal all cracks and a bead ran on the top before placing it on. I may put the white vinyl on the roof of this trailer. Have not decided on that yet. The carpet allows for rubbing on the sides and makes the trailer much quieter. Almost sound proof it seems. I am excited about this new idea. It should save me many hours over all.
The white piece is the fiber glass that I attach to the outer walls, the screw driver shows the space I have to compress the carpet. This trough will be filled with silicone before the second wall is laminated to the outer wall. This should make the lower virtually impossible for water to enter.
Bob
951 692 0958
Looking good Bob. One of these days I might get back to work on my trailer. Although after seeing your trailer and now this build I might have to scrap the box on mine and maybe do a Pod on it.
Great to hear from you. Have not seen you around for awhile. I thought about you during the Del Sol run. Did not go this year. I have just been too busy. Let me know when you decide, if I can help just scream.
Bob
Notified today that the water tank was not ordered last week as promised. Spoke with Rich at RONCO plastics, he is bailing me out it appears. They make the tanks for Plastic Mart. Really puts me behind schedule, but will not have to wait the two weeks PM told me. Rich says he will get it out by Monday. A Sooner fan, we have been friends awhile. Will deal directly with him from now on!!!
Pictures are of the driver side with the accessory doors shown and in their location. The rear driver side, the vinyl has been attached, but the wall is not permanent yet. The counter top installed, sink in and the stove are in. Passenger rear side is off to show the area of the fridge and the different wiring being done.
Notified this morning the fiberglass is ready to be picked up, so will most likely do that tomorrow, so I can work on it over the weekend.
Beginning to look like a trailer now.
Bob
051 692 0958
A few pictures of it starting to come together. Interior shot of where the action packers will set during transport, two like the one and one sideways on the front shelf. The overall look of the trailer before fiber glass is attached. You can see the tech screws going into the steel main frame. Each one is has red lock tite, the head is ground down smooth to the wood and then silicone. These are in a temporary form, will be removed for silicone along the bottom and when forced back in under the roof, silicone is applied there. That forces the silicone into any possible void, the roof is over the side walls. The exact same system is used attaching the fiber glass, virtually no way for the sides, base or roof to leak.
Bobbyjr
